ziggurcat
Hi
Iam interested to buy a Dac with eq.
Are still topping D50 iii and wiim pro plus the best option?
Do they need dedicated drivers to work as usb dacs?
Can the eq be applied to all inputs in both?
I ve read few months ago that eq is availiable only on usb input in d50iii. Have they fixed it in any firmware update?
Are there better options under 300 than those 2?I may y be to go a little higher if there is a good reason...
Topping just released the DX5 II and the D900, which both have EQ as well. The D50 III and Centaurus DACs were the only ones Topping released that had PEQ functionality prior to the release of those two devices. The DX5 II is only $300 USD, so it is the more affordable option.
If you are on Mac, you do not need any drivers for any Topping DAC. Drivers for the D50 III are available on the Topping website for PC.
On the D50 III, PEQ is only available with the USB input, and there is no plan to add the functionality with any other input for that DAC. With the DX5 II, it is available for all inputs. It is also limited to 32-bit/192kHz (same with the D50 III).
