Topping D50 III Balanced DAC with EQ Review
Rate this DAC:
    Votes: 11 2.4%
    Votes: 12 2.6%
    Votes: 63 13.8%
    Votes: 371 81.2%
Does anyone know where I can get a short 12v trigger cable like this for a D50 + A50 stack?
It's basically a 3.5mm male-to-male mono cable, about 4 inches(?) long.
JDS Labs has the stuff.
But these are 3.5 stereo, does this also work as a trigger cable - which are otherwise mono..
20cm mono trigger-cable:
Thanks everyone! I found one at JDS Labs. It's already on order.
JDS Labs 3.5mm Interconnect Cable
Length = 3in (8cm)
I hope it's not too short. I'll let everyone know when I get it.
P.S. It's stereo, but that doesn't matter in this case since only the tip and sleeve are used to control the trigger jack.
They might be, I have these for my D50s & A50S stack, and at 6" they are verging on to short.
Perhaps the thinner cable will be more flexible for you.
Is the topping tune firmware upgradable to newer versions with more functions( eg. split eq for each channel)
Or is this technically impossible and do they need eg. 2 dac chips
Does anyone know what a Source Frequency Response file is and what it's purpose is?
I was able to load some Harman OE Target curves from autoeq library .csv files. This one works.
Probably just the raw headphone response curve, in either .txt or .csv format.
Thanks for the idea! You know there are translation difficulties with these devices and their software/manuals. I'm going to try it with the raw HD650 frequency response file.
But honestly, it's not that bad for a first release of Topping's EQ software. I'm sure they'll fix some bugs and expand the functionality in future versions, as they're marketing it for their high-end line of devices.
Today I measured the A50 III in combination with the D50 III and the amp does not add any additional distortion to the combined output.
Still the same 125 dB SINAD @ M Gain @ 300 Ohms @ BAL IN/OUT.
Unfortunately, I found that the D50 III is sensitive to ground loop noise. When directly connected to a PC, the noise floor is higher with some unwanted spikes (like PC fans PWM), the H2 level is higher, and the SINAD is lower by 3 dB. When driven by a battery powered laptop -> everything is fine. This made me think about USB isolators.
Some of them seem to be overpriced, and others don't have enough power to provide 5V 500mA output devices at least.
I checked the following devices:
JDS Labs Synapse -> not enough power (100 mA max).
Topping HS02 -> cost $110 (Shipping+Taxes)
Hifime High-Speed USB Isolator v2 -> don't know if I can trust its specs to power devices with 500mA.
That's an inherent risk when using RCA interconnects. When using TRS it should be immune unless they've implemented it badly.
I am using 6" TRS cables and the unit is in BALanced mode. This is not common mode noise, but some sort of ground loop noise.
Balanced is immune to ground related noise issues when correctly implemented, which is why I asked. It's the main reason to use balanced interconnects in a domestic setting as interference isn't usually a significant problem there. It seems Topping didn't implement it correctly, which is disappointing and worth knowing. Or one of your units is faulty, or they're vulnerable to a different interference path that just sounds like a ground noise issue.
I'm going to try this once it arrives in a couple of days:
The only thing is that the maximum current might be an issue.
One source mentioned that it can only provide 200mA to devices.
Let's see if it's enough for the D50 III, otherwise I'll return it.
You were right!
I loaded the HD650's raw frequency response curve into the 'Source FR' tab and it showed up on the graph with the Source FR slider enabled.
This also changed the shape of the Filtered FR curve to a "Raw headphones + Combined filter" curve.
