Hi, can you tell me the db number your d30 is showing when used as a preamp?
I bought this dac for use in front of a hypex fusion fa503
I connect dac to hypex via XLR
I start the preamp at -99db : until -60 db i hear nothing, then from -59 to -30 volume is low. For a normal listening i need to be at -20 db on the topping.
If i crank to -10db, its a little loud but not scary
I can put -5db on the topping , it is loud but not crazy loud .. i mean my previous amp was 80w and was getting my room louder ..here hypex fusion says its 500w
Is normal as a preamp? ..i was expecting that at -95 i start to hear something and it would gradually get louder as i go down in numbers..
I'm also using a Hypex Power Amp (NC122MP) and have exactly the same behaviour. I have quite a few Hypex amps (including NC500) and they all need winding up a long way to get really loud with both my Tannoy System10's and Duntech's... Previously was using an Oppo 105D as my preamp and would be up at 80%+ for "when the Mrs is out" listening levels.
