Made it work after a few tries. The coaxial connector on the D30 is very tight and needed some power to fully attach. Thanks for your help staticV3! Have a great day!Did you supply power to the converter? All cables fully plugged in?
audiosciencereview.com
Sure, it's not going to sound any worse, but it's good to know. And if Topping has anything to say about both the D30 Pro and the D70 Pro Octo.Meh
DAC sounded fine before I read this, and it still does sound fine to me after reading it
I will only buy a new DAC when the D30 Pro dies.
Which digital filter are you using on the D30 Pro?I tested my D30 Pro DAC according to user jkim, using the file CMaj.flac as input.
The audio chain was:
NAS (with the file CMaj.flac) --> Ethernet --> Streamer Wiim Pro Plus, full volume --> Optical connection --> DAC D30 Pro, the volume set to -15 dB --> Headphone Amplifier A90 Discrete, balanced input --> Headphones Beyerdynamic DT 900 Pro X
The D30 Pro firmware version was 2.46 (the latest).
The result:
Absolute no clicking sounds, only three parts of low frequency, which indicates no problem with the CirrusLogic CS43198 DAC chips.
I also tested with the DAC volume set to -20 dB but also in DAC mode, no change.
I am using filter F-2 (default).Which digital filter are you using on the D30 Pro?
Same as I. I'll check my firmware version.I am using filter F-2 (default).
Optical connection reduces quality in all respects, perhaps because of this you could not hear distortions or your hearing capabilities did not allow you to do so. The D30 Pro also has these distortions.I tested my D30 Pro DAC according to user jkim, using the file CMaj.flac as input.
The result:
No it does not.Optical connection reduces quality in all respects
Have you tried factory reset?My D30 pro stopped working, it only shows -4 on the screen, do we know what that is? Sometimes after power cycling 5-10 times it throws err1 briefly before going back to -4
No, how do you do that?Have you tried factory reset?
Oh thanks, tried that but it doesn't really respond. It's stuck at - 4According to manual:
