Cahudson42
- Joined
- Sep 21, 2019
- Messages
- 1,083
- Likes
- 1,557
Topping D10 connected to Fire 7 via powered OTG cable, downstream to Monoprice Liquid Spark. OTG cable powered with various Amazon USB ps..
D10 erratically disconnects, clicks, shows 3 dashes, 384.. Wiggle and disconnect cables, resets correctly to 16/44.1. For a few minutes. Cycle repeats.
This is second unit doing this. I returned the first, thinking the female USB at the back of the unit was poorly soldered etc. - as wiggling the cable into it - reset it to correct 16/44.1. But the new replacement unit is doing the same thing.
Clicks, display goes to 3 dashes, maybe will reset showing 384. Have replaced the USB cable, tried various 1 amp supplies, same problem
Help! Any suggestions as to what is causing this and the solution greatly appreciated!
When it works - correctly showing on the display 44.1 while Amazon Music HD is running on the Fire, it's great. But the disconnects are infuriating..
Thanks for your help..
