Topping D10 Balanced Review (USB DAC)
nyxnyxnyx
Besides form and features, are there any good reasons I should pick up the D90 instead of this? I mean both are very capable DACs but their measurements already exceeded past the audible range, so should I just stick with what fits my budget?
Lupin
If you don't play DSD Native, you don't need to install the driver.
Unless for some reason you want ASIO support.
Other then that yeah, not really necessary.
Whoareyou
Chicago
If these had s/pdif input they would be perfect paired with the miniDSP U-DIO8 for multichannel.
Hopefully another iteration, similar to these could be released with input instead of output.
Labjr
I want to see a reasonably priced DSP device that can handle stereo 4-way crossover better than an anlog crossover, and doesn't use SPDIF out.
hyperknot
Since this doesn't have any memory for volume (if I understand right), does this default to default mute or default max volume? The Soncoz DAC with the same chip has 2 firmwares, one with default mute and one with default max. How is this handled here?
phoenixsong
If it works like my other usb dacs the pc usb port should be the one that remembers the device and its settings
Toku
Japan
DoP works for me on my DAC. I can't imagine it sounds any different than native.
My remark means the difference between ASIO Native forwarding and DoP forwarding.
Both can play DSD, but DoP transfer has restrictions and DSD256 cannot be played. So it means that you need a driver to play DSD perfectly with D10 Balanced.
HDavidson
Maybe it is worth showing Impulse Response when measureing the Dacs. Inverted or not, as it was with Topping D10. It can be convenient for correction, with the possibility of reversing it.
kukocz
PL
Sharur
raif71
My trs to xlr cable arrived to be used for D10b and balanced amp (along with normal xlr cables)
Toku
Japan
Does D10 Balanced has hardware digital volume accessible from linux/windows driver?
Do you plan release multichannel version of it? It would be great solution for active systems.
D10 Balanced is a product that combines the DDC function and USB-DAC, and the RCA output is fixed. There are no items that can be operated from the outside. There are no setting items. All you can do is connect the cables.
miofu
I thought D10s has such feature and it is builtin ESS DAC chip. Am I wrong?
