Topping Centaurus R2R DAC Review
Rate this R2R DAC:
    Votes: 29 8.1%
    Votes: 80 22.3%
    Votes: 174 48.5%
    Votes: 76 21.2%
it is if you compare digital systems with dither , which has been used for the last 30 years .
Was it only 30? The bibliography on dither in Wannamaker's PHD thesis starts from around 1960s.
you can have signals below 96dB with 16 bits with shaped dither .
Doesn't even have to be shaped dither. In attachment there is a sweep at -60 dBFS converted to 8-bit, so ~48 dB DR, with flat dither. Should still be fairly easy to hear.
I was having a conversation with Google Gemini on how ladder dacs can compete to the impressive 64-bit chip dacs that exists today. This is what it came up with:
May I suggest, not the best idea coming into ASR and try to claim the response of an LLM is gospel. Surely you knew a flamesuit would be required? :P
JSmith
My Centaurus R2R has a high-frequency noise when standby,
Has anyone else experienced this?
You got the details :) tbh I don’t know when in became practice in digital audio in the early digital audio products , I think there was a time when it was not used , it migth be that the 80’s are almost 50 years ago :D
Of all the reasons not to get a Denafrips, this must be the worse one:
Skip to about 17 min.
A brief summary of what we can expect to see/hear at 17 minutes would be appropriate according to policy...
The DSP in the Denafrips Terminator Plus is making for example a singer seem closer when he sings alone or further away when singing together with instruments, in effect remastering the song. It also made it difficult to do measurments, according to Golden Sound, so he can’t use it as a reference dac.
I stopped polluting this thread with my ramblings and continued the Denafrips discussion in the only Denafrips dac review on audiosciencereview:
Post in thread 'Denafrips ARES II USB R2R DAC Review'
https://www.audiosciencereview.com/...ares-ii-usb-r2r-dac-review.11166/post-2528456
I would take ‘golden sound’ with a large pinch of salt.
Yep, a very large pinch of salt. I'm highly skeptical of a claim that Denafrips has DSP that can move a singer up and back in the soundstage depending on whether other instruments are being played. That would be an incredibly sophisticated DSP with some real breakthroughs in technology.
Maybe it uses something similar like Izotope Ozone VST plugin.
Edit: The video shows an effects plugin for studio software that can help separate vocals and instruments in a song.
This was a response to the doubts that DSP can’t change vocals in a song, here is an example of AI-assisted VST plugin often used by (amateur) recording engineers when mastering in music studios. The DSP plugin causes abouy the same latency observed with the Denafrips Terminator Plus (200ms).
Don't make me post the video drop policy at you again. :p
So it comes from the chassis? It must be the power supply. Several appliances do that when they are in stand-by.
My description of the video content was accurate. Is there a new rule now?
I will happily elaborate what I meant with the DSP plugin example. What Golden Sound describes is happening with the Denafrips Terminator Plus sounds a lot like a mastering plugin like Izotope Ozone, that I have used to separate instruments in my bedroom studio. Someone thought that this was not even possible. Izotope Ozone even use AI for this task. This explains the 200 millisecond delay in the Terminator Plus, which is a lot.
For simple tasks FPGA DSP should be hardware based and super fast, but 200ms latency is that of VST plugins used in DAW software like Cubase in studios. Using a VST plugin like Isotope Ozone introduces signifiacant latency up to 5-400ms.
We need someone to dissect a Denafrips!
What description.
Is not a description of the video. Even if it were the statement "The video describes the Ozone VST plugin" is not a sufficient description.
The whole point is that the reader can glean from the description if the video content is of sufficient interest to them to make it worth watching a video about it. In the policy link I gave you is an excellent example of what this description should ideally be like :D
The sound comes from the DAC.
Is this normal? I have other topping dac ,that don't have this noise
Also the VST plugin argument is ridiculous ! especially to justify some youtubers imagined subjective impression of DAC doing things a DAC cant do .
It will be coming from the internal power supply. If it is loud enough to bother you when you are sharing the room with it, then I'd try to get it changed. If not, then it is probably not worth the effort.
If by this you mean that it comes from the "box" and not from the speakers or headphones, then it almost surely comes from the power supply.
It can happen with some appliances when they are in stand by. It is a sign, usually, that something it not perfect in the power supply (either design, or implementation, or condition). If you can only hear it in close proximity to the DAC, and not from the listening position, it may not be a problem.
Is it like coil whine?
That's usually a sign of a some bad cap but that should be weird, this DAC is almost brand new in cap's terms.
I would replace it if still in warranty.
In quiet conditions, it can be heard from 6 feet away. Once I realize this, there's no way to ignore it, so I'll send it for repair.
