Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
This is sort of BT related, but I would be really interested in a formal Spotify via BT vs Spotify direct client comparison. I have done one, via an phone supporting LDAC and Spotify Direct on my AVR. Spotify via LDAC bluetooth shows an APtx like noise around a tone. Spotify direct is worse, with noise around the tone plus a whole bunch of harmonics!
Amir, do you use Roon with the phone as the output? I find that when I use my Pixel phone as a output (not as a remote) that there is a 3 to 4 second delay from when I press play in Roon to when audio begins. Issue doesn't appear at all with Windows wifi devices.
Ah. Ok. Thanks. I thought it was pretty much a global android standard since android 9. I'm on a OnePlus 7 pro using Android 11 for reference and I have support for all the codecs except LHDC, but I have no clue who uses that.
Another excellent review of an excellent product. Just ordered one (I am guilty of having bought 2 Auris BT at almost twice the price).
Thank you Amir!
Yes I used Roon. I tried Neutron player briefly but it showed more artifacts so I abandoned that. There was definitely some delay from pressing Play to when the output started.
I did find some but haven't measured directly.
There were clearly more artefacts using Spotify direct than via BT. I will try and test again on the weekend. My previous ones had BT audio level issues so not quite a fair comparison.
Are you using the Pixel as a Chromecast device? Just thought because the Pixel is Google hardware, it might register itself on the network as a Chromecast device. In that case, Roon might not be using RAAT to stream to the Pixel like it does to Windows WiFi devices.
I'm using my phone as the enabled audio device. The Roon signal path shows the file is sent to the phone using RAAT. The default output is AAudio. Starting music or seeking within music has 3-4 second delay from when I push the button and when music begins playing. I can duplicate the issue on two different Pixel phones and on a new Samsung tablet. The issue does not appear with Windows devices or funnily enough when using a actual Chromecast (connected to my TV) as the audio device. I assume it's some kind of weird android audio issue with Roon.
@fieldcar there are apps with embedded support for LHDC (like HiBy Music for instance), of course reciver still needs to support it. @Rottmannash Hibi UAT does support higher sample rates than LDAC while maximum bit rate is similar. Of course that doesn't tell us how good codec really is. Would be interesting to test both of them (UAT and LHDC).
