Topping B200 or Class D Purifi 6525 ?
pdodo2003
Hello, I would like to ask if somebody had the chance to listen to both of them ?
Purifi 6525 from audiophonics and Topping b200 ?
Which one would sound better , my speakers are floor standers Canton Karat L900 and my dac is Topping D50 III balanced out .
Which one would be the better musical sound perspective choice ?
Thank you
If the speakers’ impedance dips well below 4Ohm, go for Purifi. Both amps are transparent hence SQ can be expected to be the same.
They won't sound different, but the Topping will use more electric power.
Thank you
I had the same thought but foolishly posted in the review thread, so my question got lost in the flurry of posts.
I think the purifi modules would make more power. They might potentially handle low impedance speakers a bit better too.
I'd be using whichever amp with an AVR so ideally I think I should try to get an amp with a gain near to 29dB (to match the AVR's internal amps, which will still be doing the surround channels).
So the high gain setting of the Topping B200 (22dB) is a bit low, but would probably be ok. I think the Audiophonics one would be something like 25.5dB.
I'm one of those who would prefer an internal PSU, but the power bricks wouldn't be a deal breaker. Otherwise, I like the small form-factor of the B200s.
The B200 has much lower distortion and I love the fact that (maybe because it is class A/B) the distortion remains consistently low even for higher frequency input. The graph showing higher distortion for 15kHz input has been enough to prevent me from going for one of the Hypex or Purifi class D modules until now.
Although it is very nice conceptually to have such a low distortion amp, it is so far beyond audibility that I doubt the difference between the B200 and the Purifi would matter at all.
I have some slight concerns about the long term reliability and service support with Topping. I'm not trying to slam Topping here, it would just be a major pain to have to post it back for service. With the Audiophonics I would be quite happy to do a module or PSU swap, if needed, at some later stage.
In an ideal world I'd be buying three Benchmark AHB2s, but I can't stretch to that at the moment.
Thank you for your input . Yes , budget is to be had in mind , in a budget free world the choices would be different , but money are hard to make these days ...
To remain on subject, Amir was so kind to answer me the same question on his YouTube channel for Topping B200 review . Amir s opinion was to take the audiophonics , because of the higher power . So that is the way to go :)
Thank you all , I will order the audiophonics Lpa S450 - purifi 6525 .
To be understood ,I already have a Emotiva Basx A300 and a set of Fosi V3 Monos with separate 48v 5a powers supply's.
So I hope to be able to distinct something in the sound in the good way.
I will keep this posted here on my news when the amp arrives .
Well. I ordered the topping b200 pair and will try it with the philharmonic BMR towers next week
Will see what happens
Any caveats? Should I drive these with something else?
