Topping B200 monoblocks with Focal Aria 926
OldRaggedDog
I am considering an overhaul of my audio setup. I am replacing my current DAC with MiniDSP Flex and my current integrated with Topping B200 monoblocks.
Despite glowing reviews, I am a bit afraid it may not go well with my Focal Aria 926 (they reach as low as 2.9 Ohms at upper bass).
Besides, I am a little bit confused with the specifications of the power amps that state:
8 Ohms: 200 watts
4 Ohms: 200 watts
This is unusual to me since the amplifiers I am familiar with usually deliver more watts into 4 Ohms compared to 8 Ohms.
I have attached an impedance graph of Focal Aria 936 (haven't been able to find the same graph for Focal Aria 926 but it looks pretty similar to this one)
I need someone to either assure me that I am going to be fine or otherwise tell me this is a bad idea. I have those Toppings available at a local shop and itching to get my hands on them.
I
I am using a Wiim Pro streamer into the MiniDSP flex(balanced) feeding a pair of B200 monos. My speakers are Wharfedale Lintons. My speakers dont drop quite as low as yours, nor for as long. I also high pass them at 48hz, though this has no effect on the lowest impedance range.
That said the B200s don't even break a sweat and are bareley warm too the touch. I run them on the low gain giving me headroom as well as requiring less signal attenuation.
I am able to tolerate full volume for a song or two on the low gain setting, but it is by no means comfortable listening. I usually end up around -10db when I want it loud. High gain got scary loud at -10db and I dare not go louder.
I personaly think they will work splendidly with your Focals given their high sensitivity and nominal impedance of 8ohms, even if the dip down for a bit. I am very happy with my setup so I may be a bit biased. I can't imagine you ever needing the high gain setting.
Here is the same impedance curve for my lintons. They are 6 0hm nominal where yours are 8. 90db sensitivity where yours are 91.5db
I'll also include a few pics of my setup
I'm using B200 to drive Dynaudio C2 platinum and they work very well.
I drove my Focal Aria 948 with Denon x3400h and x4700h and could not find any problems with it (except for the fact that 948 is too big for my room and could be bass bloomy because of the proximity to the wall)
you'll be fine.
