Not really, Danny actually changes the crossover topology in his so-called upgrades. Like his re-engineering of the Ascend Sierra 2EX V2 speaker which changed the crossover, not just swapping components with the goal of selling expensive stuff. I was talking about the mindless urge that people have to put various boutique capacitors in their speakers' passive crossovers, despite electrical evidence.You're talking more about stuff like the GR Research speaker/crossover, "upgrade," kits?
For sure, Danny feeds this mindless urge to swap parts of supposed different qualities, rolling his eyes at sandcast resistors, disrespecting good capacitors in favor of more expensive ones that serve the same electrical purpose, and spreading FUD on inductors. This is what @Maniekok was talking about, replacing stock crossover components with Mundorf capacitors and getting "More micro-dynamics, a sense of air, and clearer instrument separation." Which is unfortunate since if he used the same values, the Mundorf's will perform the same, depsite the fact they aren't very good capacitors from an electrical perspective. You should read the link on capacitor testing to see what I am talking about. And some links that @ctrl has posted.
Capacitor upgrade in crossover - Is it audible?
As the topics "capacitor upgrade" and therefore "capacitor sound" is very controversial, the test method and its results are explained in detail. This cannot be dealt with in one minute. Sorry for this and I hope your attention span is still sufficient to read through a long text - whereby the...
www.audiosciencereview.com
Audible difference in high-end capacitors? - ABX samples
As announced long ago the last part on the subject of audibility of capacitor upgrade in crossovers. The comparison ranges from a very cheap, decades-old film capacitor to an expensive high-end capacitor. As promised, this time there are short audio samples of each capacitor (in a simple...
Replace resistor by low-inductance resistor - Is it audible?
Since it is often claimed here in the forum that replacing cheap sand-cast resistors with low-inductance resistors would lead to clearly audible improvements, and since it's no use pointing out that the sound change (unless it's completely imagined) is very likely due to slight deviations in the...
Different Binding Posts - is it audible?
The influence of BP on the sound of loudspeakers has often been controversially discussed. It even goes so far that individual voices describe the influence of binding posts as immense and recommend only very high-quality BPs - That made me curious. The full mini series: Capacitor...
The other thing I was talking about and also linked was passive-bi-amping, which people are perennially confused about, including this thread.
