Or you’re lazy and have an AI do it:From those measurements you can compute the current as I=(P/Z)^0.5.
It depends on the load impedance. Also, Topping's specifications state that the measurements for the specifications were made using 220VAC/50Hz for the mains power. If you have different mains power, as we do in the U.S., the output power may be a little lower. In the first post in this thread Amir lists output power for different load impedances, presumably using 120VAC/60Hz. From those measurements you can compute the current as I=(P/Z)^0.5.
Regular Class AB 100W RMS @ 8ohm amps, like old NAD 2200 offer 60A peaks, being able to handle real speaker load and not collapse when the things get going.
How many amps peak can B200 provide?
Oh, I just saw it.. that's ridiculous, 7A?! You have to be very careful when choosing speakers for this amp, if you want to use anything but desktop speakers.
Pfffff...
Amir should start talking about current capability of the amps and how much is really needed to listen music loud with the proper bass and music peaks.
www.audiosciencereview.com
I don't know where you got the 60A peak number from, but that is not anywhere near what Amir measured. At 4 ohms he measured, per CEA-2006/490A, 520.9W on one channel and 541.3W on the other channel, which are 11.4A and 11.6A, respectively.
NAD 2200 Vintage Amplifier Review
This is a review and detailed measurements of a refurbished and upgraded NAD 2200 stereo amplifier. It was bought by a member, sent to QuirkAudio to be fully updated and then loaned to me. The work that Peter has done is exemplary. The inside looks brand new! I have repaired hundreds of...www.audiosciencereview.com
Nonethless, the NAD 2200 Is a good amplifier. If you can find one for a good price, get it.
From that article: "The output transistors of the NAD 2200 amplifier are high-powered, fast-switching devices capable of delivering some 60 amperes of peak current for brief periods." But, is the rest of the amplifier, including the power supply, capable of delivering 60A? Maybe, but there is no test data in the article confirming that is the case. Indeed, as noted, Amir's test results are not anywhere near 60A.NAD 2200 Power Amplifier Review price specs - Hi-Fi Classic
www.hifi-classic.net
Is Amir measuring average or peak power? Dynamic transients need more than average power.
You are missing the whole point.From that article: "The output transistors of the NAD 2200 amplifier are high-powered, fast-switching devices capable of delivering some 60 amperes of peak current for brief periods." But, is the rest of the amplifier, including the power supply, capable of delivering 60A? Maybe, but there is no test data in the article confirming that is the case. Indeed, as noted, Amir's test results are not anywhere near 60A.
Let's assume that 60A is a true measurement. In order to do a proper comparison, you would need to determine the test conditions used to measure 60A, and then replicate those test conditions for the B200. Otherwise, you are making an apples to oranges comparison. The only apples to apples comparison we have are Amir's measurements, and there the differences are not anywhere near as high as you claim.
Why are we not saying B200 is a desktop amp, not a real typical amp that can be used to listen to music from 3m distance at anything over 5W with speakers that are 89dB/1w/m or less?
People read "200W amp" and asume it's a powerful amp. No, not even close, with its 7 amperes.
I couldn't understand why all these desktop amps sounded so punny when I put them to work and now I get it... if you listen loud to dynamic music, they will compress the sound, it will sound flat.
You are assuming both speakers are playing mono signal, adding 3dB?
Only drums? Ok, but orchestral music is not like that. Jazz is not like that, music is not like that.
Maybe +1dB and that's it.
3 ohm dip would try to pull 16A peak/381W.
Edited to show B200 specific values in addition to the example that had been requested. Changes/additions in red.Regular Class AB 100W RMS @ 8ohm amps, like old NAD 2200 offer 60A peaks, being able to handle real speaker load and not collapse when the things get going.
Pfffff...
But it ain't got no Hypex or Purifi powerThis is nonsense.
For home audio listening, unless the speakers are extraordinarily inefficient, 100W would deliver ear-splitting SPL. Much home listening is done at 1W or less.
Extremely high amperage is unnecessary
The electrical theory is straightforward and has been shared in several posts. Class AB amps follow the same laws of physics as class D amps.
Certainly rated power specs for amps need to be taken with a grain of salt, and load impedance varies with frequency, but for an amp rated at 100W
Any speaker demanding 60A from an amp would have to be an unrealistically low impedance. A 2 ohm load pulling 60A would see 120 VRMS --- that's 7200W!
- driving an 8 ohm load, the amp would need to deliver 28.3 VRMS and 3.5A.
- for a 4 ohm load, it would need to deliver 20 VRMS and 5A.
- for a 2 ohm load, it would need to deliver 14V and 7A.
What SPL can the B200 deliver?
Let's run the numbers on the SPL that a B200 would produce in the case you presented (at 3m distance with 88dB/1w/1m speakers).
Recall:
88 dB SPL --- SPL produced from 1W
- while dB power is calculated as 10log(P2/P1), dB amplitude (such as SPL) is calculated as 20log(A2/A1).
- adding a second speaker increases SPL between +3 dB (for incoherent/out-of-phase sources) and +6 dB SPL (for coherent/in-phase sources)
- 9.5 dB SPL --- SPL reduction at 3m distance (i.e., 20log(3/1) = -9.5 dB SPL)
78.5 dB SPL --- SPL at 3m when 1 speaker is driven with 1 watt
From information provided by Crown alongside one of their calculators, we find two formulae that can help us:
1) dBW = Lreq - Lsens + 20 * Log (D2/Dref) + HR
2) W = 10 to the power of (dBW / 10)
Where:
Lreq = required SPL at listener
Lsens = loudspeaker sensitivity (1W/1M)
D2 = loudspeaker-to-listener distance
Dref = reference distance
HR = desired amplifier headroom
dBW = ratio of power referenced to 1 watt
W = power required
Let's start by working backwards from 84W (max power of the B200 when driving 2 ohms, where the amperage requirement would be highest)
84 = 10^(dBW/10)
dBW = 19.2
With that we can approximate the SPL using
19.2 = Lreq - 88 + 20log(3/1)+0 (since we are not interested in amplifier headroom at this time, HR can be ignored)
19.2 = Lreq -88 + 9.5
19.2 = Lreq -78.5
Lreq = 97.7 dB SPL
The second speaker would add another 3 to 6 dB SPL, raising the volume at the listening position to over 100 dB SPL. That's the sort of volume one encounters in a nightclub. In fact, experts recommend no more than 15 minutes of exposure per week at that level without hearing protection.
If the speakers were 8 ohm (instead of the 2 ohms used above), the Lreq figure would be 100.5 dB SPL so that, with two speakers, one could expect at least 104 dB SPL at the listening position.
Characterizing the B200 as "a desktop amp" is ridiculous.
This needs to be repeated more here on ASR. I've had people jumping out of their chairs with mere 2x15w connected to a pair of Ino Audio piP bookshelf speakers.Characterizing the B200 as "a desktop amp" is ridiculous.
I'm afraid you are wrong. Check the excel terryforsythe created. Second speaker by no means adds 6dB. BTW, we are not talking about avg spl at all. Speakers are also no resistors and dip below 4 ohms easily.The second speaker would add another 3 to 6 dB SPL, raising the volume at the listening position to over 100 dB SPL. That's the sort of volume one encounters in a nightclub. In fact, experts recommend no more than 15 minutes of exposure per week at that level without hearing protection.
Agreed, I won't be parting with LA 90 discretes, -10dB is max I can go with them before sound collapses, but it's usually loud and dynamic enough. For parties, I do have to switch to one of yamaha power amps, LA 90 simply runs out of steam.I think we can agree that, for you and your listening preferences, the NAD 2200 is a good fit. That does not mean, though, that the B200 is not perfectly suitable for the listening preferences of other people. Every use case is different, and it is great to have a lot of different options.
You seem determined to twist data to suit your opinion.I'm afraid you are wrong. Check the excel terryforsythe created. Second speaker by no means adds 6dB. BTW, we are not talking about avg spl at all. Speakers are also no resistors and dip below 4 ohms easily.
Good luck with low current amps.![]()
Hypex and Purifi are both excellent technologies. So are amps made by Benchmark. You'll get no argument from me on those points.But it ain't got no Hypex or Purifi power
And I still think this B200 ain't got nothing on Benchmark.
Can you show your calculations in assuming this?Maybe +1dB and that's it.
You assume a 6dB reduction per doubling of distance in a room. But you conveniently ignore the reverberant field. Why is this?For a single speaker we're talking around 112W to get to 100dB at 3m.
