Topping recommends two ways of connection with B200: D90III DAC and Pre90. I suppose B200 shall be set to High with D90III, right?
I have D90 III and B200 with 87dB-sensitivity speakers, sit 2 meters from my speakers, listen at about 75dB average/90dB peaks, with album-level ReplayGain enabled, but no room correction and no PEQ (so no additional negative pregain applied other than ReplayGain) and Low Gain on B200 is still loud enough for me regardless of whether I go directly to B200 from D90 III (set to pre mode) or I put Pre90 between D90 III in DAC mode and B200.Topping recommends two ways of connection with B200: D90III DAC and Pre90. I suppose B200 shall be set to High with D90III, right?
To the defense of the expensive testing equipment, they present an ultra healthy, more than 200 kOhm input impedance (so, complete immunity, as they should) .At the end of the day, it's testimony to the engineering of Topping that their devices are measuring at the limits of available testing equipment costing $ 50,000 plus.
You feed the damn thing trough line out and it gives output to mesured gain, main purpose of preamp is hard limiter so you can't blow the speakers. I don't see much of other nead for serious preamp other than well serious stage equipment attached to very long balanced cables especially this day's when you are better of doing that in digital domain in the first place and much better of using such multichannel one as main point and preamp (audio interfaces with DAW's, self stand DSP processors or power amplifier integrated one's). It doesn't do low impedance loads well thanks to it's design as output is bridged (two output stages in one). Don't pair it with speakers that deep lower then 4 Ohms and it will do fine. No one will use such amp for subwoofer and most sensitive (huge) PA speakers (over 100 dB/W at 8 Ohms) will be dead silent with it.According to this review: B200 review the LOW option on B200 is not very promising with D90III DAC. This same review also indicates B200 lacks of bass and sound stage. Can anyone confirm it?
Presumably, this “report” would also have something to say about rhythm and pace, as well as about a holographic presentation. Or the lack of the former. This audiofool nonsense never ends.This same review also indicates B200 lacks of bass and sound stage. Can anyone confirm it?
It's possible when paird with certain speakers that drop to 3 Ohms or lower but that much would have been intentional don't under estimate voodoo outcome it's usually calculated.Presumably, this “report” would also have something to say about rhythm and pace, as well as about a holographic presentation. Or the lack of the former. This audiofool nonsense never ends.
He tries them with Magico S3 which are 2.8 ohm minimum. EPDR is one ohm. Totally unsuitable speaker for these amps.It's possible when paird with certain speakers that drop to 3 Ohms or lower but that much would have been intentional don't under estimate voodoo outcome it's usually calculated.
What exactly would you like to know?Can anyone make a comparison between B200 and Teac AP505, which is slightly more expensive?
Treat him to some percussive education with a length of clue by four.Asking for a friend...
