ThanksView attachment 508892
I am driving these speakers (88 dB, 4 Ohm) in low gain mode. And they can play louder than I would want them, in a fairly large living room.
Hi do I have to use the high gain into 8ohms on the B200 to drive the Wharfedale Linton?
The Wharfedale Linton has 6ohms I think. Can I use the low grain into 4ohms on the B200?
All those lovely coaxial speakers. A man of fine tastes, good sir!FYI, I have my B100s set to high gain powering the tweeters in my Elac speakers (concentric drivers). I do not hear any noise, even when putting my ear inside the midrange right next to the tweeter. I have LA90Ds powering the midranges.
As a comparison, when doing the same with my KEF LS60s, which have their own amplifiers built in, I can hear a little bit of noise, but it is not audible 1m away.
I used speakers with separate midranges and tweeters for decades. After my experience with the Elac and KEF concentric drivers, I am never going back to separates.All those lovely coaxial speakers. A man of fine tastes, good sir!
Similar experience for me with KEF, although nowadays I listen to a pair of MoFi SourcePoint 8 standmounts (more Andrew Jones magic!)I used speakers with separate midranges and tweeters for decades. After my experience with the Elac and KEF concentric drivers, I am never going back to separates.
I think so. I would use a pair of B200s or a pair of LA90Ds bridged mono.Will these drive KEF Reference One Meta?
The speaker is designed to be very revealing, meaning it requires robust amplification to handle the challenging, low-impedance load and drive them to their full potential,
How do you turn on both the amps if your pre-amp has only one 12v trigger out?Genius!!! This solved the issue. I had to configure the pre-amp in it's setup menu and set the 12v trigger to "on". I assumed (I should know better not to) the 12V trigger is always active. Thanks so much @BeeKay
With an inexpensive splitter:How do you turn on both the amps if your pre-amp has only one 12v trigger out?
The B200 comes with a trigger cable with split.How do you turn on both the amps if your pre-amp has only one 12v trigger out?
Mentioned hereThe B200 comes with a trigger cable with split.
Nathanowl,@amirm Would you be willing to offer feedback to Topping here?
I love the amp and would buy a companion unit in the same form factor—a single-box LiFePO₄ battery with integrated charging that the amp can sit on. It would power the amp for X hours, seamlessly switch to AC/DC when depleted, and eliminate the bulky external PSU. I’d buy several of these combos. Nothing cleaner than battery power. I'm suspicious about that 240W external supply...
I'd bet you a $400 scope and the included probes would show a ton of ripple on that included PSU. I bet it's pretty bad. I'd bet you see 50-100mV ripple on thereNathanowl,
I have tried batteries for preamps and amplifiers. Used standard lead acid for amplifiers. Wanted the horsepower. Vaporized a chunk out of a stainless blade one time when trimming lead wires. Not sure how many amps it took, I am sure hundreds to instantaneously vaporize a stainless knife blade. Loud pop and metal was gone.
But results are what counts. The LA and B series Topping amplifiers deliver the lowest distortion and noise ever seen in a commercial amplifier. With the Topping power supply.
The batteries generate noise. From the chemical reaction. Also have internal impedance.
You would never hear the difference. If you purchased the 30,000.00 analyzer and borrowed a low noise, wide band amplifier with 40dB of gain you could measure the noise levels.
I am sure the battery power will measure worse than the cheap looking wall warts Topping provides.
Take my advice with a grain of salt. It is from someone who just replaced ALL the metalized mylar capacitors in some complicated speaker crossovers. Used anti-series connected polar electrolytics for all 10ufd and up values. Used paper in oil for tweeters.
But spent a couple months gathering and testing options. Extremely happy with outcome.
Topping may not be interested in a smart battery supply. But no one can stop YOU from cobbling one up.
I hear your opinion. Can you back it up?I'd bet you a $400 scope and the included probes would show a ton of ripple on that included PSU. I bet it's pretty bad. I'd bet you see 50-100mV ripple on there
I think we both will listen longer than our neighbors. The natural gas here stays on when electricity goes off.Besides... what happens in the apocalypse when *you* don't have power anymore? I'll be listening to music![]()
