D
Deleted member 72219
Guest
Depends on your metric, yeah?I think Purifi is more perfect than Topping.
For some, it is literally just the SINAD or THD+N.
For others, there are other factors at play, clearly.
-Ed
Thank you, nice to know, that with higher gain of 22dB and 2V input that the B200 is still 1dB of clipping. Clipping is not a good to occur, especially for Speakers, is it?And the higher gain of 22dB is more than enough to drive the amp to clipping with the typical 4V out of a balanced DAC. Even with 2V out you can get it to within 1dB of clipping.
Hi Ed,Depends on your metric, yeah?
-Ed
No....a quick question.
Does the Topping B200 monoblock have a balanced output stage?
Wouldn't it be better to determine this on several complex loads to better understand the amplifier behavior?that would show absolute peak values for SINAD with Topping
We may not have the same needs. I have 2 LA90 toppings, 4 LA90D and an AUDIOPHONICS HTA400ET, 4 ways.Hi Ed,
yes, there are now many established hi-fi companies that use Purifi modules and sell them very expensively because they complement beautiful VU meters and / or brand emblems.
In my opinion, this is also a sign that even established “high-end” companies cannot realize better circuits themselves.
I don't think there are currently any better amplifiers on the market than the Purifi with the corresponding power supply units.
Without wanting to discredit Topping, I tend to use a diagram like this (this is for Phones) for my internal evaluation that would show absolute peak values for SINAD with Topping, but would be in the middle range for load stability and absolute power.
I think Purifi would achieve top values in almost all areas.
What do you mean by this? It is a bridged output...meaning both + and - speaker connections are driven...do not ground either output....a quick question.
These are XLR preamp or monitor outputs.What do you mean by this? It is a bridged output...meaning both + and - speaker connections are driven...do not ground either output.
You talkin' to me?These are XLR preamp or monitor outputs.
To my knowledge, I have never seen them on power amps
Edit : I have a question about your system. Is it a stereo active multi-amp or a home theater system? If it's a stereo system, which channels are the B200s designed for?
You talkin' to me?
Wow.....just wowI'm not f*** your wife
I'm hoping it was just a badly judged movie quote. But if that had been directed at me I'd be using the report button.Wow.....just wow
Microsoft's translation is indeed explicit. But Google Translate is less definitive about the meaning.I'm hoping it was just a badly judged movie quote. But if that had been directed at me I'd be using the report button.
"Wow" is an expression of shock or amazement. He was expressing amazement and or shock at the crass nature of your post.Microsoft's translation is indeed explicit. But Google Translate is less definitive about the meaning.
However, I think "WOW" should be understood as "Don't get carried away."
Reading Babadono's response to Tomchris, it seemed clear to me that there was a problem with the understanding/translation of Tomchris's question. Matt Holland had answered Tomchris accurately. I was simply adding a question to Babadono about these amplification choices (LA90D-B200; it must be said that this thread is seriously lagging behind).
It was just an ironic response to the rest of this passage in the film, which is more than classic in France."Wow" is an expression of shock or amazement. He was expressing amazement and or shock at the crass nature of your post.
I feel the choice of quotes was ill-advised, no matter what the intention. From the outside looking in, the quote appears at-best to be a lapse in judgement, and at worst, an attack on a member of the forum. Best not to use such provocative of word use, joking or not. Given the lack of available, contextual facial expressions a face-to-face interaction might have indicated of your intentions, comments of this nature are bound to be taken badly in an internet forum.Some people were quick to hit the report button to report me.
