70% efficiency for a basic class AB design with a linear power supply. The advantage of linear power supplies lies in their EMI cleanliness but not in the efficiency which offers a constraint not the least, their obligation to oversize them. This oversizing has limits because it induces another factor of increase in noise induced by the quality of the more resistant components.
The advantage of the SMPS is its high efficiency, and its peak response in correlation to its The disadvantage: the large number of harmonics generated by the switching process. Due to the high frequency and the complex spectrum, it is not easy to filter them.
By using a more powerful SMPS, the harmonics will increase in power at different frequencies.
This remains to be confirmed, we do not have the schematics: I think that the Topping LA90, LA90D and B200 certainly have a programmable input processor to cancel these harmonics. Using a more powerful SMPS would probably require updating this firmware via the USB-C stamped "FW". Which may not be enough to obtain such good filtering efficiency.
This programmable processor may have a more advanced function than a simple harmonic cancellation function.
I can't find the information, but if these topping amps use power DMOS transistors operating in class AB, it would be a kind of proprietary BASH amp with a similar operation to class D.
The advantage of operating DMOS in class AB lies in the reduction of electromagnetic interference and inerrant distortion to the switching of class D.
These types of amps optimize efficiency, by continuously adjusting the supply voltage according to the amplitude of the amplified audio signal, a constant voltage drop is obtained at the terminals of the output transistors, independently of the output amplitude.
Since there would be no more switching at the output, there remains an impedance adaptation, less influential than with a basic class AB because of the adjustments of the amplified audio signal.
However, these adjustments are limited to the maximum possible voltage drop at the terminals of the output transistors. And that the limitation to 153W in 8Ohms of the B200 is induced by other factors than those of the AB class.
I think that this limitation varies according to the input audio signal and the capacities of the input stage:
- OPA on D90,
- discrete on LA90D in pushpull configured in bridged mode.
- discrete on B200 but in mono, so no bridging of the input stages is possible.
The pushpull being a symmetrical assembly (- 0 +) which allows to double the power and improve the SNR.
The use of OPA for the XLR inputs does not allow to use the OPA of the L & R channels for the bridged ones.
On the other hand, it is probably possible in discrete:
See the quadrupled power on the L90D
If these toppings do indeed use DMOS transistors in class AB, I think that the limitation of the B200 to 153W/8Ohms is not induced by the power supply but by the simple fact that it only has a discrete mono input stage.
