I can only relay what Topping recommended. For average efficiency speakers use the LA90 Discrete. For high efficiency speakers or lower listening levels the B100’s. Never mentioned B200. Maybe cost.
I think I can hear the difference between B100’s and PA5II. So 125 SINAD vs 105 SINAD. The difference was audible when listening to low level strings and piano.
I was using a Micromega integrated. It is very quiet, but sounded distorted at normal volume in comparison. On orchestral works if clean recording had some fuzz. Never heard it before listening to B100. Using same RAW-MDA1 dac as source and volume control. The redundant source selector and volume control in the Micromega may contribute.
The B100 are 124 - 125 SINAD. The THD and noise are below the intrinsic level of an APx555B. Topping had to amplify the output by 40dB to measure it with an APx555B. Then divide by a 100 to get the numbers published on their website.
If Amir had used this technique the four Topping amps that top the chart would not all measure the same. Doubt that a digital chip amp, digital discrete amp, Class AB amp, and Class B amp all measure the same - 120 SINAD.
Topping ranks them as B100 (125), B200 (122.3), LA90 (122), and LA90 Discrete (121).
