Topping B100 Amplifier Review
Rate this amplifier:
    Votes: 30 6.4%
    Votes: 27 5.8%
    Votes: 82 17.5%
    Votes: 329 70.3%
You’re far better off letting your Marantz handle the Martin Logans than relying on the little B100.
you really think so? based upon the answers from Gemini AI, with my average listening levels, speaker specs, distance to the speakers, & small size of my room, it doesn't appear I would need anything more than 80 watts. I thought that in my use case, a super clean & transparent sounding amp would be more beneficial, despite the lower power rating(?)
There are no audible benefits to what you're planning. Your Marantz already operates with noise and distortion levels that are inaudible. Swapping it for an amp with half that noise and distortion doesn’t change that -it’s just an exercise in numbers, not in real-world improvement.
On top of that, the Marantz offers more power than the B100, if and when you need it.
Bottom line: you're not gaining anything by going down that route. In fact, you'd likely end up with less power, a more complex setup, and extra cabling for no practical benefit.
gotcha, thanks for the advice...hopefully I can cancel the order before it ships LOL
Are you sure the distortion is inaudible? I don't see any benchmark or measurement for this AVR.... tons of AVRs are complete trash in terms of performance... even if they are expensive.
Complete trash?
How much distortion can you actually hear? Most people first notice distortion with the below tests around –21 dB, which translates to a SINAD of 21 or about 9% THD.
This is the Marantz:
That's SINAD of 62.
So yes, the distortion from the Marantz is going to be inaudible for the vast majority of use cases.
actually, I would agree this Marantz (SR5006) sounds clean already... I thought initially it would be underpowered for the ML Source electrostatics, but it seems to drive them fine even at -10db (volume) which is the loudest I could tolerate in my listening room
@Old_School_Brad what do you think of the "OSD Nero HTA4200", it's a 4-channel amp at 140wpc (8ohms)... but bridgeable to a whooping 400wpc for 2-channel stereo, seems to be good bang for the buck? it's within my budget. Thinking of ordering this instead once I get confirmation from walmart that the B100s are cancelled
Complete trash?
That's SINAD of 62.
62 is trash. I can hear a SINAD of 80 without an issue. I even heard products that had a SINAD over 90, I could tell when comparing 2 high quality songs. Now I am not sure the resolution of his speakers, but 62 SINAD is total trash.
From an objective standpoint, a SINAD of 62 dB is far from "total trash" -it's already below the typical threshold where distortion becomes audible in real-world music listening.
Your claims of perceiving differences between 62, 80, or even 90+ dB SINAD would need to be supported by rigorous, double-blind testing to carry any weight.
Or, at the very least, a screenshot of your results from the Klippel test I shared earlier.
If your claims do stand up, then honestly -I don’t envy you.
I'm not familiar with that amplifier.
It’s worth mentioning that if your goal is better sound quality, swapping amplifiers probably won’t help unless you’re already reaching the limits of your current amplifier’s power and hearing distortion at high volumes. And if you do, there's potential in freeing up some power reserves by crossing your Martin Logans higher than 40 Hz.
"complete trash" is a relative term. They still generally measure with inaudible levels of noise and distortion, expecially when you consider they are being used with speakers - not headphones.
For example my Denon 3800 got criticised by Amir - but mainly because it's DAC performed slightly less well than it's predecessor, and Amir likes to see things moving in the opposite direction.
It still gets 85dB SINAD, 18 bits of dynamic range, and the multi-tone grass being mainly below -100 dB.
Far from state of the art compared to the best stereo amps - but still inaudible noise and distortion in real world listening with speakers. Oh, and lands well into the green section for the amp tests. For me - it sounds great.
And then bear in mind, most of the issues are coming out of the DAC - so will be passed on in any case to any external amp.
I mean, I came to find this website because I heard an audible difference in some DAC's and people argued with me. Specifically with the Schiit Modi Multibit and the Fulla2, then compared with an SMSL M8. I sent all these DAC's in, including the Topping D30 for testing in the year I joined this forum.... and I brainstormed with Amir about testing that could reveal these problems.... hence the linearity and multitone tests we still use today.
I definitely heard it, called it out and Amir validated my thoughts. This has happened on multiple occasions over the years with this forum in specific.
I can definitely hear the difference, and do so repeatedly.
I suppose it would matter what kind of music you listened to and what kind of speakers or headphones you used. In my case; I heard these differences using a headphone like the DCA Aeon Flow Closed and 1More Quad Driver IEM's.... two of the lowest distortion headphones tested on this forum.
However, when SINAD goes under 80; things become much more difficult to hear (easier to tell apart)... where microdetails in many songs disappear and Violins start to sound like flat garbage in the high notes.... if you just listen to rock from 50 years ago.... that has a Dynamic range of about 5... so you probably won't hear any differences no matter what you are listening on... but if you listen to modern day well recorded music especially in the classical world; honestly I stopped being able to hear differences past 105 SINAD... anything beyond that I couldn't tell no matter how hard I tried... 95 to 105 is also much more difficult with the right song and volume to hear the differences in resolution.
I also did this with several blind tests years ago with my friends when we used to have regular audio meetups at my house... even using a switcher box (a transparent one) or with Amps that have the ability to switch their inputs around.
I agree with your lack of envy on my "ability" because honestly, my life is a bit ruined with audio now. I have high quality stuff, but when I go places... especially after I trained my ears... I can definitely hear when things sound like crap and it bothers me. Once upon a time I was fine with some $10 headphones coming out of an audio jack.... and I listened to over 4000 hours of music on a Realtek integrated sound into some Panasonic RP-HT360's... Once I found Hi-Fi and actually heard a difference (first device was my HTC 10, which had a superb headphone output w/ dedicated amp)... it started my journey which "ruined my life" in some ways haha.
I can tell you though that people with decent hearing can definitely train their ears. I was able to train my wife (she plays violin and went to music school for 2 years) and she is also able to hear differences which she can pick out more than 75% of the time in a blind test, with devices upto around 100 SINAD.
Alright, I’ll take your word on it for now. However, as you mentioned, you were using headphones, which is a completely different scenario, on top of that they’re among the lowest distortion options available.
Taking these outlier factors into account;
  • Extremely low distortion headphones
  • Much better than average hearing
  • A trained listener
-you must also acknowledge that this isn't a concern necessarily relevant for the average enthusiast who listens to speakers in a room.
The Marantz in question would with all likelihood be perfectly transparent to such listeners, as suggested by listening test results.
With that in mind, it’s also important to recognize that 0.0x% THD+N is far from "complete trash."
Properly controlled and blind right?
Because otherwise - the two events of hearing differences, and seeing measured differences might be (and quite likely are) completely unrelated.
AVR's are used with speakers. And consequently distortion from them becomes much less audible as it is masked by the much higher distortion from the speakers.
Sure, as I said.... it depends on the resolution of the speakers and the source material. Some modern day speakers really have quite low distortion.
However I would love to actually test one of these receivers with the speakers I just purchased, because I think I would be able to hear the difference especially with violin related songs.
I have a playlist on Spotify (also Tidal) with a collection of songs that all have different specific elements and tones in the songs, or very low background microdetails which is part of where these differences are heard with higher than normal distortion. Remember that the base distortion is multiplied for every tone. So if you start with high distortion; you can lose alot of accuracy very quickly.
So I can agree that there are likely many scenarios where people don't notice the distortion, mainly due to source material, quality of speakers, and lack of trained listening to details. So technically speaking; the performance of such a 62 SINAD Amp would be sufficient in those scenarios.
I just say that in the world of Hi-Fi; we should be using products with a better resolution as such products do exist and are quite affordable today (maybe not in an AVR, but I am not certain about that market).
Yes, I did controlled and blind with level matched settings from the different sources.
The interesting thing is that once I identified differences and told people what to listen for in a song; they were mostly also able to pick out the differences also while blind.
Sometimes the differences were so big that we could tell the difference even purposely playing with the level in an inverse manner. These details and such are the easiest to pick out on higher frequency tones. They are the ones which are distorted first and the most.
So songs with a well recorded higher note Cymbal, Piano, Violin.... even flute (as in the extremely well recorded album "Night Passages" by Martin Frost) there are parts of songs where in specific a difference can be heard, with microdetails lost (or an entire note being flattened, depending on the severity of the distortion).
In my normal listening though... 90+ SINAD with under 0.4db Linearity deficiency is "fine" usually until I encounter a "problem song" and that usually sends me on a testing spree. So practically speaking; as I work I listen to all devices which have over 105db SINAD, so I don't have to adjust my volume knob 99% of the time (unless I get into a song and start jamming out and turn it up :D)!
Some of the most well regarded active speakers here include amps at the 70's SINAD realm.
Anything remotely decent behind the speakers can do under conditions.
Gain-staging and sane choices are far more important than distortion.
I don’t agree. Why pursue components that offer even more inaudible noise and distortion than what’s already imperceptible? There’s simply no practical need to exceed what 99% of us could ever hope -or need -to hear. Beyond a certain threshold, the pursuit becomes pointless. Fortunately, that threshold isn’t difficult to achieve from a design and manufacturing standpoint.
The only reason I responded is because I sensed a bit of the usual elitism that often pops up in claims of exceptional hearing ability. But I’ll leave it at that and wish you a great day! :)
I would argue in that sense that the separation gets better due the mono block system. For me the soundstage got wider for sure.
There is one thing worrying tough is that the electrostatic speakers usual dip below 4 ohm which we know it has a chance to trip the B100's saftey mode.
In case you have a return window then I would try it at least.
Spot on. People usually forget this but gain staging is one of the easiest way to improve your overall system.
I would love to see your blind testing logs (and hear about your test arrangement).
I don't have logs, since I didn't do the testing to make a thread on this forum. I did it out of my own interest along with my group of friends who are all into Hi-Fi.
I've written about the arrangement through other posts over time, I don't feel like typing it all up again. So go search for my posts and read about it where I have written about it before some years ago.
The funniest thing about this thread; is that we went from talking about science and audible transparency; to arguing about whether or not you can hear the difference on devices with hugely audible distortion and lack of resolution of any kind. It seems that people on this forum love to argue about everything, which wonders to me why you would be into Hi-Fi at all... just buy a $15 pair of speakers because everything sounds the same... the $15 speakers have 50 SINAD and that wouldn't have audible distortion either.
So without a double blind ABX study with scientific logs; nobody can tell me that $5 speakers from Walmart sound different than $2500 speakers or $25000 speakers...
The insanity of some people on this forum really surprises me sometimes.
I like high resolution sound. If not why spend money on speakers at all? Get a sound bar and call it a day. If you don't care about audio quality, then why sign up to a forum like this or spend money on high end audio? The whole idea of having nice speakers or headphones, is to have high quality electronics which will be able to power them transparently.
I just switched the speakers out in my Church from old school PVi-10's and a Pyle Sub driven by a Crown CT2000S, to a Klipsch RP-8060FA Gen II pair, w/ RP-500M II Stage Monitors, driven by a Fosi v3 for Stage + Fosi V3 Mono Blocks for the 8060FA II's.. w/ a R-100SW sub driven by a D50 Gen III DAC.
