Topping B100 Amplifier Review
Rate this amplifier:
    Votes: 29 6.7%
    Votes: 24 5.5%
    Votes: 78 18.0%
    Votes: 303 69.8%
I don't understand the debate here.
We have two sets of data from experienced operators (Amir and pma) who speak for themselves.
Can we move on please?It's on Topping's side now to prove otherwise and our opinions are of little use.
Class B (AB just not closed), PSU 38Vdc (2x19V), 4ohm load, power analysis at 9W/4ohm
One transistor power loss in the BTL mode is almost 18W. At 9W usable power.
With almost same results.
Note: @miero might try 5W/8ohm (6.3Vrms) sine for 5 minutes. It would eat only about 8W per transistor. Or 10W/8ohm (8.94Vrms).
Helpful diagram for this, from a famous application note from Burr-Brown (AB-039, POWER AMPLIFIER STRESS AND POWER HANDLING LIMITATIONS, 1993):
For 100W output power this amounts to 40W dissipation in the amplifier worst-case (when output power is also 40W), and that is for purely resistive loads. Conservative design is more like assuming 60% of output power to be dissipated in the amp, with the corresponding implications for thermal design.
It would call for a heat-sink with about 1...2°C/W (effective in-situ!) which of course would be huge....
Yeah, and BTL is a specific case, when transistors are in fact loaded with a half of load impedance, 2 ohm in case of 4 ohm resistor. Pretty tough, though not such voltage stress.
It is able to play 50Hz tone having 5W into 8 ohms for 7 minutes without shutdown. Then I stopped the test.
Temperature of the amplifier bottom (hottest part) raised to 42 dg. C.
Reactions: pma
I am posting facts, not opinions. That is a big difference from vast majority of posters here, who post based on emotions mostly.
The facts are clear. But if we have several measurements under different conditions giving different results, then by preferring only specific measurement conditions in your statement you are only making an opinion.
According to Amirm, the amplifier has dozens of watts of power, and according to you it is only 5 watts.
Well, and it's cool that you measured in your own way. you wrote about it and anyone who wants can read it. I respect that.
Meanwhile, you've repeated it a dozen times in this thread and thus muddy it up.
If I understand it right ... Is not in the way you describe and enables that pma needs to repeat again :)
Amir measurements is about power capabilities and pma measurements are about continuous power. Sounds similar ... but it isn't.
Maybe pma can answer more clearly, I'm not an electronic expert and maybe I'm wrong
With a stepped sine we have almost same results with amir. Everyone who has a basic knowledge of measurements can see it. If not, then it is not my problem. I am not going to re-measure the amp. There is no reason.
Amir: 50W/8R, 86W/4R
Me: 54W/8R, 94W/4R.
The difference would be in burst lengths.
The whole discussion is about the rated power. Rated power would be 5 minutes sine into 4ohm and 8ohm. This is something we still do not know. We know positively that it will be far below the stepped sine results. @miero can do the job himself - he has a DMM and the 8 ohm load and that is all he needs. Depends if he wants to do it. He is an amp owner and has to decide.
But, frankly speaking, we know that the rated power of all those small Chinese amp boxes is a scam. Not only of this Topping B100. They notify no standards, just some hausnummer numbers.
hausnummer
Guessing there is a less literal translation than "House Number" Pavel? Im guessing it alludes to made up? Or meaningless?
Great. 5W/8R .....
Would you mind to go higher?
Targeting the 10W/8R, the B100 was also able to play 50Hz for at least 7 minutes without shutting down, then I stopped the test.
The temperature of the bottom of the amplifier (hottest part) rose to 45 dg. C, which was only 3 dg C hotter than during the 5W test.
It also seems to me that the small heat sink inside the case is not where the most of the heat is transferred. There are more screws on the bottom of the amplifier case than I would expect just to hold the PCB in place.
Perhaps adding a larger heat sink to the the bottom of the case and standing the amplifier vertically might help in the long run.
I would guess that the main bulk is at the small heatshink though by the fact that the bimetallic switch is installed on it.
Except there's a second one somewhere underneath (which would be a good thing,they are notoriously inaccurate about their ratings)
Let’s say that we estimate, from Amir’s and my stepped level measurements, the rated power to 8 ohm as 50W/8Ohm/1kHz. Then:
1) make 1 hour pre-conditioning at 6.25W/8ohm
2) make 5 minutes sine test at 50W/8ohm
Or, derate the rated power.
Not opinion, measured data, confirming the amplifier's inability to meet the current FTC power test. It is failing a defined test standard.
Amir's test is a short-term sweep, not a continuous power test, per the FTC (Federal Trade Commission). A short-term test usually does not stress thermal or other limits whilst the FTC continuous power rating is meant to do exactly that. Many of us lived through the days of wild power claims before the FTC (and various other countries' governing bodies) stepped in to provide some reality and sanity to the marketing claims.
Pavel @pma did not perform some random test he made up; it is a test defined by the FTC. His position has been clear and reasonable during this whole thread despite the protests of those who wish to make up their own definitions and ignore the FTC standard.
ASR is all about holding manufacturers accountable for meeting specified performance standards.
Load 8Ω: (OK) 8.9 Vrms / 10W ... 7 minutes of 50Hz signal
Impossible with normal btl class-(a)b and that small heat sink. Total heat generated is 30W.
Reactions: pma
Not sure what your units are here. 110dB SPL is deafeningly loud and will result in ear damage pretty quickly.
And for most systems, -110db on a volume control is going to be below the threshold of human audibility.
I fixed that, thanks. Truthfully at 68 ears old, I might be at -90 in my ability to hear distortion in amplifiers. I'm not sure that's age related. I've never actually tried to anything systematic to figure that out. I've just noticed things like the Mini-Dip HD, when added to my system, sounded transparent to me, even though it added measured noise.
Maybe something really new...
The T'ang-ku-la Module uses a brand new three-stage feedback circuit technology. It reduces circuit noise and high-frequency distortion, thereby increasing the dynamic range of the power amplifier to 151 dB. This technology also significantly lowers the heat produced by circuits, further boosting the reliability of the circuits, extending service life, and effectively diminishing thermal noise.
Source: https://www.toppingaudio.com/product-item/b100
