Level stepped sine is exactly the method to approach slowly to the rated power. The result was shown in my test. And it was shown here how “slowly” it rises. Post #950 and #952.
Purifi (with 2x46V power supply)
You may also like to visit my HomePage where you will find more tests and also the NC252MP tested according to IEC60268-3
Exactly. Especially the Purifi 1ET400A, it has much cleaner ultrasonic spectrum than the NC252MP and during the tests I have never experienced the amplifier shut down. It stays cold even at full power (with sufficient heatsink). To me, better choice than class AB with same power rating.I'm not an electronic engineer or with a deep knowledge about electronics.
Briefly (to stay on topic) ... these amps seems to be aligned with the specifications and decent alternatives to good classic class AB amps.
Class D has great efficiency at high output power, but that is not your typical home use case.I should -seriously- start thinking to try some of these "new wave" amplifiers.
Currently using some old, power-guzzlers AB or tube amps, and I'd like to see minor amount on my monthly energy billing.![]()
I received a response from Topping with annotated "THD+N Ratio vs. Power" graphs on Balanced input, that were already available on their website. Not surprisingly, they provided nothing new that we didn't already know.OK, thanks. I replied them with a request for a clarification on the actual power output capabilities.
Color of the photo is tricky,it seemed blue-ish to me and thought they were Nichicon.I received a response from Topping with annotated "THD+N Ratio vs. Power" graphs on Balanced input, that were already available on their website. Not surprisingly, they provided nothing new that we didn't already know.
Regarding the 38 volt and 4 ampere power supply. Inside B100 there are 8 capacitors, probably CapXon 220uF 25V, 105 dg. C.
Because of 25V rating I assume they are connected in parallel as four pairs in a series. So the overall capacitance there could be 440uF 50V.
440 µF is not exactly an ample local buffer, but maybe enough if there is sufficient capacitance residing in the power brick.I received a response from Topping with annotated "THD+N Ratio vs. Power" graphs on Balanced input, that were already available on their website. Not surprisingly, they provided nothing new that we didn't already know.
And in comparison with internal photos published at Audiophonics the IRF5210 was moved from the PCB above these capacitors to the main PCB between these capacitors and under the power connector.
I'm sure the picture was taken through the vent hole from the other side. I can see the same on mine.440 µF is not exactly an ample local buffer, but maybe enough if there is sufficient capacitance residing in the power brick.
Did you take your B-100 apart to make that picture? Would you care to peek under the PCB that sides alongside the heat sink and maybe also peek underneath the heat sink?
Judging by the similar in power Xbox's PSU at this teardown,there are a couple of big-ish caps in there (if they are similar)if there is sufficient capacitance residing in the power brick.
If I were the customer, I would rather ask them according to which standard they specify the rated power. And I would recommend to OEM assemblers here (@boXem , @Buckeye Amps , @Audiophonics and others) to make such specifications as well. You will need to do more testing, but it is a necessary part of the job and business.I received a response from Topping with annotated "THD+N Ratio vs. Power" graphs on Balanced input, that were already available on their website. Not surprisingly, they provided nothing new that we didn't already know
The power supply used is a DC SMPS located on the end of probably a 12ft run (2 core) of wire. A measly 38V@4A (claimed) capability, into a standard 2 pin microphone plug/socket for a "power amplifier". Right oh
| Number of Contacts | 2 Pin | 3 Pin | 4 Pin | 5 Pin | 6 Pin | 7 Pin | 8 Pin | 9 Pin | 10 Pin |
| Contact Arrangement |
| Rated Current | 7A | 7A | 5A | 4A | 4A | 4A | 4A | 4A | 4A |
| Rated Voltage | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 |
| Withstand Voltage | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 |
| Insulation Resistance | 1500 | 1500 | 1500 | 1500 | 1500 | 2000 | 2000 | 2000 | 2000 |
| Contact Resistance | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
| Panel Cut-out | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
| Contacts OD | 2.45 | 2.45 | 2.45 | 2 | 1.15 | 1.15 | 1.15 | 1.15 |
