A pair of B100 Monoblocks can output 100W per channel at 4Ω, or 70W per channel at 8Ω.What can a pair of these mono blocks drive in terms of wattage.
This http://www.hometheaterengineering.com/splcalculator.htmlWhat can a pair of these mono blocks drive in terms of wattage.
I just watched from where your link begins and have objections right away.This http://www.hometheaterengineering.com/splcalculator.html
and the Dezibel X App may help you to find out, if this is enough power.
The Topping B200 has the same SINAD specs but twice as much power for twice as much cost.
The Fosi V3 Monos have less SINAD but are exactly in the middle between these Topping gems if you are asking for „enough“ wattage.
And this guy explains exactly why power is „nearly everything“ that counts in case the amp has at least a few other qualities…… He likes it to have 450 Watts at 8 Ohms (and I strongly recommend his video!):
For some systems that may be appropriate. For others, that is overkill. There are numerous factors that affect how much power is needed. Yesterday I started a thread and posted a link to a spreadsheet to do some rough calculations to determine the minimum amount of power a system should have.He likes it to have 450 Watts at 8 Ohms
audiosciencereview.com
Is slew rate / high Bandwith an indicator for good acceleration? I am no expert.I just watched from where your link begins and have objections right away.
THD < 0.1% inaudible? really??
Sound is about cone acceleration not THD and that is is justification for needing high power and high damping factor? In fact, it is the best argument for current drive, because a = F / m and F is proportional to the B-field which is proportional to the current. There go all his arguments for high damping factor.
Seriously, if the source has a certain max level and the amp a certain gain, if the resulting output is within the linear range of the amp, no amount of extra headroom or current capability of the power supply will make a difference.
Sorry having to agree with you.Is slew rate / high Bandwith an indicator for good acceleration? I am no expert.
Damping factor is needed to make frequency range / and how the frequency response is independent from the Ohms (Resistence fluctuation) of the speaker. So very nice to have.
Slew rate is a time domain measurement pertaining to how fast an output signal is able to move between voltage rails, e.g., when testing step response of an amplifier. Bandwidth is a frequency response measurement. Bandwidth may have some correlation to slew rate, but not necessarily a direct correlation. As long as they are adequate for the frequency range over which the driver is operating, I don't think they have much impact on cone acceleration. But, I have not looked too deeply into it.Is slew rate / high Bandwith an indicator for good acceleration?
Damping factor pertains to how well an amplifier is able to control overshoot of a driver. It generally is a concern more in the bass region than the higher frequencies. It does not pertain to frequency response, but instead how well the amplifier is able to control the driver.Damping factor is needed to make frequency range / and how the frequency response is independent from the Ohms (Resistence fluctuation) of the speaker. So very nice to have.
No myths from me. From you, maybe?Ah, the old myths about damping factor. Depending on how well you crossover is designed, you can probably get away with a few tenths of an Ohm of series resistance, e.g. 0.2 R total resistance of amp output, terminals and cable will result an a damping factor of 30 in an 8 Ohm speaker (which will be around 6 R) without having significant impact on the frequency response.
It doesn't change the Q of the driver itself, but instead changes the Q of the system including the driver.As far as bass goes, series resistance changes the Q of the driver and hence the alignment of your bass box, no metter whether it is closed, bass reflex or transmission line. So whether you have a damping factor of 50 or 200 is probably not going to matter much, but eliminating the passive crossover can change the alignement which is audible. This is not about better "control" but different frequency and transient response.
I think you misunderstood what they are saying. I haven't read the white paper, but a series resonant circuit has minimum impedance at the resonant frequency. A parallel resonant circuit has maximum impedance at the resonant frequency.If you were out to minimize harmonic distortion, you'd want as high as possible source impedance. This is actually what Purifi recommend in their white paper for the alu cone drivers: have a series resonant circuit that increases the series impededance exactly at the frequency that would have its harmonics amplified by the cone mode.
But the crossover in a passive speaker is the predominant factor in determining the damping factor. Unless somebody is using an amplifier with high output impedance, e.g., a tube amplifier, the output impedance of the amplifier is negligible.A few tenths for the total of amp output impedance, terminals, cable, NOT crossover.
Yes, the Q of the system changes, and thus the alignment of the system. That is a separate issue from the damping factor of which I was discussing, which pertains to the amplifier's control over the woofer. Adding resistance in series with the woofer decreases the amplifier/speaker system damping factor.About Q, it is still about the driver inside and out of the box. Series resistance will make it behave like it had a higher Q_es. And yes, that changes the alignment of the system.
That's fine for a midrange or tweeter, but to do so on a woofer will decrease the damping factor. It is a compromise. In my opinion, it is not a compromise worth making on a woofer that is going to be used to play low-mid bass.It is an example where a manufacturer that takes HD seriously proposes using series inductance to lower HD.
harmonic distortionCan you tell me what HD means?
Thanks!harmonic distortion
LOL (also an acronym)Glad you asked that for me.
From acronyms anonymous, or AA to avoid confusion.
Does this mean there is no more power for music dynamics?That's not correct. Its peak, continuous and max powers are the same due to enforcement of protection circuit. Actually, in testing, it seemed to allow a bit more peak power before shutting down. But wasn't worth capturing and including in the review.
As long as your music dynamics are within the 100W/4Ω power budget, all is well.Does this mean there is no more power for music dynamics?
