No, it doesn't. You'll note SINAD is just one of many measurements carried out here. All have to have good results for transparency.More you have a high sinad system ( read more transparent, as it relates to sinad mostly)
I'll give you that the human brain is certainly more imaginative than any measurement devices. Blind studies tend to dampen or eliminate those profound differences many claim to hear. A book I've often recommended is Dr. Cordelia Fines "A Mind of its Own". it explains how our brain distorts and deceives us. Its not directly about audio but our brain does not turn into a scientific measuring device because one utters the word " audiophile".Human brain is much more sensitive than any current measuring equipment.
How many degrees warmer, and what physical, verifiable parameter corresponds to "realism"?It's on warmer side of neutral and has insane realism specially when you feed directly by a dac with in built volume control.
But the tests *were* run at 50mW:If tests were run at 50mW instead of 5 watts the incredible low noise, distortion, and high linearity at low power would be very evident.
At five watts, the average loudspeaker with 4Ω impedance and 86dB sensitivity will output 90dB SPL.At five watts many speakers are already distorting.
Amir runs (mostly) the same tests for each Amp.The distortion vs output for the B100 are run to low levels. The amps to compare to are not.
So you mean all good measuring amps, dac and speakers sound identical?How many degrees warmer, and what physical, verifiable parameter corresponds to "realism"?
The closer they get to good the closer the answer to your question is yes, yes, and no.So you mean all good measuring amps, dac and speakers sound identical?
DACs and Amps Yes. Not speakers though. And amps have to be operating within limits (not clipping)So you mean all good measuring amps, dac and speakers sound identical?
And how did reach that so called cut off limit beyond which all dac and amps sound same ?DACs and Amps Yes. Not speakers though. And amps have to be operating within limits (not clipping)
But then you have already been told this, multiple times.
www.audiosciencereview.com
Amps and DACs yes. If you disagree, feel free to provide objective, verifiable evidence.So you mean all good measuring amps, dac and speakers sound identical?
Please tell where that threshold value of sinad mentioned in the above post beyond which all dac sound same. I find limits of human hearing but not the sinad limits of equipments. IBecause research of audibility thresholds are performed and the results published.
For example,
Keith![]()
Audibility thresholds of amp and DAC measurements
Introduction A recurring theme on ASR is whether or not the various measured qualities of the devices are audible. In this post, I'll present some clear and visual thresholds for when those imperfections can be considered a potentially audible concern. I will not explain the basics of amp/DAC...www.audiosciencereview.com
Exactly what I am asking. What is that "objective" limit of sinad beyond which "it starts not mattering". Which "objective" Test fixed that limit? Or the limit was fixed "subjectively" by some golden ears. This is not trolling imo, because if beyond certain limits objectivity itself doesn't matter then there is no point of ranking equipments based on sinad isn't it ? Also there is no point of brands like topping to break their own past records. Why brands keep improving distortion figures beyond a certain point if it's not audible?Amps and DACs yes. If you disagree, feel free to provide objective, verifiable evidence.
