terryforsythe
The issue is that the results will apply to those speakers and that listening distance and, very likely, speakers having tweeters at or below the same test tweeter efficiency and at equal or greater listening distance. In your tests, what speakers do you use and what listening distance do you use?Of course, but that sounds like a bit of a straw man. Blind tests to determine amplifier noise should be (and are) done using exactly the same speakers, at exactly the same listening distance, in the same room.
If someone is shopping for an amplifier for their system, which may use different speakers and a different listening distance, how do they interpret your test results? Is there a compensation table provided to help people translate the results to their particular use case, or do they need to break out a calculator (assuming they understand how to perform the computations)?
