Topping A900 released: insane beast
Human Bass
All the specs are overkill. Crazy power, crazy low distortion, crazy dynamic range. Plenty of inputs and outputs. Topping didnt spare anything.
As long the QC is good, all hail the over the top king.
Impressive, glad I don't need it though
$1,199.00 USD
JSmith
Excellent result. Will I buy, nope.
Going to save money and buy another property to ride the uptrend.
Doesn't have a digital input? USB? S/PDIF? Toslink? AES/EBU? Ethernet?
Impressive indeed, however I'm a speakers man, so no interest to me.
A power amp to match the D900 could be a tempting combination though.
They call it a headphone amp/preamp, but it only has one output which is labeled as "pre" (ie before the volume control). In what way is that a preamp?
"PRE output" = Preamp output
= input signal passes through the Preamp with -0.1/+10.3/+19.8dB gain and the relay attenuator, but not through the headphone Amp.
Seems very powerful, almost doubling power ehen dropping impedance from 32 to 16 ohms.
High current capabilities, also balanced r2r volume control similar to hpa4.
Interesting option with resonable price
Relay-switched resistor-network volume controls do not use R-2R ladders.
Yeah, it can fry headphones even quicker that the glorious L30.
QC is definitely something that Topping has to work on.
As for volume control lets say it was an unfortunate mental shortcut :p from my side
For such specs, it is rather inexpensive, any western company would charge at least 5k for something similar.
Definitely, for me, this is the Chinese equivalent of the Niimbus US 5 Pro.
Topping seems to have put a lot of effort into this device, including its development.
Addendum: However, it should also be noted that the Niimbus, like other devices from this manufacturer, is very solidly built and tested and will last at least 25-30 years. Repairs to these devices are also not a problem, inexpensive, and can be performed by many repair shops worldwide, not just the manufacturer.
Probably an ideal amplifier for horn speakers like the Avantgarde Acoustic TRIO with an efficiency (1 watt/1 m) of > 109 dB. Nominal impedance 19 ohms, recommended amplifier power > 2 watts.
Low-noise amplifiers are always in demand, especially because of their efficiency.
This thing looks awesome, but you only need that much power for the Mod House Tungsten. Looks like a perfect pairing though. Seems like the Tungsten is the source of this recent arms race for headphone amp power.
