Topping A90 Static Issues (help please)
bigvibe1739
Just got this beauty and I was super excited for some A/B and enjoying my music :) Unfortunately, I am starting to hear white noise/hiss and more noise when I move my mouse when I'm plugged into the Topping.
Topping > Grace SDAC > Motherboard
Can someone give any tips on fixing this :(
JohnYang1997
China
You can also get a balanced SDAC or upgrade to a balanced DAC like schiit modius or soncoz la-qxd1
Stephen
I also had some issues: clicks and distortion with the A90. I fixed everything changing USB plug position (plugging it as far as possible from Bluetooth/Wifi antenna), I have a USB-C plug at the back of my computer and used it to provide power to my DAC LA-QXD1, so I also changed that: now it has an independant charger. So now: USB PC -> USB LX-QXD1 -> XLR A90 -> XLR Neuman KH120A and HD650 work like a bliss.
B
bigvibe1739
Just put electrical tape on the gnd pin of the USB cable you use for the Dac, that should solve it in the cheapest way possible
Whatttt lol actually? I'm learning new things everyday
mt196
Rome, Italy
I did it with mine and there is no noise, you just have to be precise in putting the tape just on that pin, you can help yourself with a needle.
Now I am waiting a custom USB with no gnd pin from pexon cables, to have a cleaner result
B
bigvibe1739
That's very interesting. I was hoping I wouldn't have to spend another 50-100$ on top of this. Will report back after some testing and when my M500 comes in the mail this afternoon
JohnYang1997
China
There little chance having it since they have balanced connections.
B
bigvibe1739
That's a relief! Thanks for clarifiying and for being so quick to support this
Martin
Cape Coral, FL
Even better yet put tape over both the power and ground pins. The cheapskates guide to making a data only USB cable. :)
Martin
Martin
Cape Coral, FL
My DACs doesn't work when power is grounded that is why I just suggested to pin the ground
The USB cables I use between my NUC and D50 and my Raspberry Pi and DX7 Pro are data only: no ground and no power. I started with electrical tape over the pins but now use custom built cables.
Martin
B
bigvibe1739
Martin
That's badass. you build them yourself? Very intrigued about this process
