If anyone is looking for more measurements
https://zhuanlan.zhihu.com/p/124309617
It tests lots of the same thing but repeat all test for low, mid and high gain, as well as 32 and 300 ohm load.
I did not read it when I linked it, now I have. First this is written some time in April and oldest comments shows 1 month ago and updated on May 25th. There was a batch sent out in April to some Chinese testers my guess is they tested that one and may or may not be updated with retail on May 25th.
The measurements are all in English so everyone can just read it. They did point out a few things:
1. For 33 ohm they can push to 15W before clipping, the reviewer list it as area for improvement but to me that's more like a highlight.
2. If you change gain or volume, performance to decrease for about 10 secs or so, then back to normal. Likely no effect on normal use at all, but take note if you are trying to do some test involving change gain or volume a lot.
3. Another thing they believe not to be SOTA is crosstalk with low gain, not bad, but considered to be average for balanced amp, and that measurement improved with mid and high gains.
4. Everything else is amazing and easily best of the best on market.
