The DC blocker is implemented for unbal input so no issue there. If the bal output of a device has large DC the unit is faulty.
In terms of EMI, it's actually not that hard to deal with. In the worst environment, A90 won't do the job because it has ground pin. A totally floating device will be immune to the actual issues in the studio. And usually it's the instruments(pickups), the boutique devices themselves have the inherent issues in these respects.
Hello,
I have 3 question I'm wondering,
I'm not expert in electronics, but have some basic knowledge, still learning XD
Currently using D90 MQA,
Getting the A90 soon,
1) I see both D90 A90 power supply utilised the GROUND Pins,
With the use of balance XLR which have another presence of Ground connection linking each other,
Will there be a ground loop issue?
Since my experience coming from THX 887 which does not have GROUND and all grounding is link to the DAC which have GROUND pin through the XLR interconnect. Without plugging any cable to the THX 887, it's case is full of statics!
2) I see A90 have a 49Vpp swings in BAL IN BAL OUT,
So the Vp should be 24.5V?
When I calculate the max voltage capable (17.32V) using 0.5W at 600 ohm
So I'm a bit confuse, which is the max voltage output? 24V or 17.32V?
Since the highest gain is 6.0x (15.5dB)
Balance in 4V x 6.0 = 24V
So.. Was wondering if A90 HP BAL OUT would clip if I use the highest gain? No matter the volume?
Because my previous THX887 6.6x highest gain clip straight away with balance 4V input no matter what volume I used.
And I obviously don't listen at this level haha, just curious and good to know about if it clips or not.
3) What's the benefit of high voltage swing Vpp in Audio? Better dynamic range? Imaging? Less clipping?
