Yes. But I don't have to have hum at all. I don't at present. I never had it on the balanced circuit. I've eliminated it on the unbalanced side by using optical.
The improvement is relative to the use of the coax. Of course the signal improves in that case, by eliminating the hum.
It would only be a factor if I put the coax back.
I can't be reaching to the back of the amp every time I switch from balanced to unbalanced circuits - it's not practical. I use both and balanced and unbalanced inputs and outputs. I have one set of balanced phones and one unbalanced. I bought the amp partially for the remote, so I'm not up and down switching my amp manually.
I'll restate my question - please forget the other issues and my particular setup. And it's fine if you don't have the answer
Within the amp - regardless of the rest of the system - does having ground lift 'on' have any measurable deleterious effect on the signal, compared to 'off'? Either in balanced mode or rca mode? I.e. does the lift only eliminate hum, if present, and leave the audio signal entirely unaffected?
Furthermore, would I be altering my balanced signal, by leaving lift engaged, on the balanced circuit, which does not suffer hum at all?
Let me deal with the 'worry' side of things. I've ADHD and will worry anyway. I accept psychoacoustics as an issue too. Just want to be sure there's no measurable issue that might affect the best possible quality of the signal chain. Then I don't need worry about anything anyway
Thanks for your efforts in trying to help, but you're missing the essence of my gist here
