Topping A70 Pro vs SMSL H400 vs Speaker Amp route — or something else? Best amp to drive the HE6SE V2?
n6o6n6
I recently acquired a Hifiman HE6SE V2 and I'm now hunting for an amp that can actually do it justice. My current setup is underpowered for it, so I'm looking to upgrade properly.
I've been looking at three directions but I'm very open to other suggestions:
Option 1 — Topping A70 Pro
Plenty of power on paper, balanced output, modern measurements. Seems like a safe and well-reviewed choice, but I'm curious whether the real-world performance with the HE6SE lives up to the spec sheet.
Option 2 — SMSL H400
Specifically built with high-demand headphones in mind. The power output looks appropriate, but I'd love to hear from anyone who's actually paired it with the HE6SE or HE6SE V2.
Option 3 — Speaker amp route
I know this is the "traditional" recommendation for the HE6SE. Open to suggestions on which speaker amp at a reasonable price point would be the best match.
Option 4 — Something else entirely?
Not married to any of the above. If there's an amp you think is a better fit for the HE6SE V2 that I haven't mentioned, I'd love to hear it. Budget is flexible for the right choice.
Appreciate any firsthand experience or strong opinions. Thanks!
HE6se V2 owner here. I’m currently running mine from a speaker amp with the hifiman speaker adapter.
I went with the speaker amp primarily because I had a receiver kicking around and was on a budget. I also have a Topping L50 that I previously used with other headphones. It actually does a better job with the HE6se V2 than I expected, but it still leaves a bit to be desired.
Given your situation, I would probably go with a dedicated headphone amp like the Topping A70 Pro or SMSL H400 that you’re considering. I’ve considered both of those myself and still am. Unless you specifically want to use a speaker amp, I think a dedicated headphone amp makes more sense here.
One other thing, do you already have a dac with xlr outputs? You’ll want to run the amp balanced if you want to get the most power out of it.
I use a HE6se with a Topping A90 and A90D with a balanced connection. It works perfect. A speaker amp is not needed in my opinion.
If I would look for a new headphone amp I would choose a Topping A70 pro, but a Topping L70 could be an option too.
Even a Topping DX5 II should be sufficient.
Topping A70 Pro
Single ended (6.35mm):
16Ω: 2 x 6000mW (THD+N: Under 0,1%)
32Ω: 2 x 3000mW (THD+N: Under 0,1%)
300Ω: 2 x 330mW (THD+N: Under 0,1%)
Topping A90 Discrete
16Ω: 2 x 3300mW (THD+N: Under 0,1%)
32Ω: 2 x 2000mW (THD+N: Under 0,1%)
300Ω: 2 x 250mW (THD+N: Under 0,1%)
Topping L70
16Ω: 2 x 3500mW (THD+N: Under 0,1%)
32Ω: 2 x 2300mW (THD+N: Under 0,1%)
300Ω: 2 x 290mW (THD+N: Under 0,1%)
Topping DX5 II
16Ω: 2 x 3300mW (THD+N: Under 1%)
32Ω: 2 x 2200mW (THD+N: Under 1%)
300Ω: 2 x250mW (THD+N: Under 1%)
Balanced (4.4mm/XLR4):
16Ω: 2 x 17000mW (THD+N: Under 0,1%)
32Ω: 2 x 12600mW (THD+N: Under 0,1%)
300Ω: 2x 1370mW (THD+N: Under 0,1%)
16Ω: 2 x 9800mW (THD+N: Under 0,1%)
32Ω: 2 x 6700mW (THD+N: Under 0,1%)
300Ω: 2x 1000mW (THD+N: Under 0,1%)
32Ω: 2 x 7500mW (THD+N: Under 0,1%)
300Ω: 2 x 1150mW (THD+N: Under 0,1%)
16Ω: 2 x 7600mW (THD+N: Under 1%)
32Ω: 2 x 6400mW (THD+N: Under 1%)
300Ω: 2 x 990mW (THD+N: Under 1%)
I went with the Schiit Ragnorok which is basically a speaker amp and still didn't achieve the sound I was expecting.
It's a white whale.
Hey, thanks for the reply Stanner (and also zonk and Mort too) :)
Yes I have a dac with xlr outputs. I plan to run the amp balanced too.
All more a reason to go with a70 pro or h400. Those have more than enough power even if you eq your headphones with a bass shelf applied.
If you dont eq them I bet a topping L70 would be more than enough. Without eq my L50 could get them to far beyond comfortable listening levels on high gain, and that makes less power than the L70.
Considering the a70 pro or h400 is within budget, just go for one of those two. That way, you wont have an itch for an upgrade in the future, or regrets that you didn’t get the one you wanted.
Happy listening
Happy listening
Yea, I think I will go with the A70 pro or H400 :)
Happy listening too.
Did you end up getting anything over the week? There is a good deal on an h400 on Canuck Audio Mart, and I think I am going to pull the trigger on it, especially for the asking price.
I like the speaker set up, and it sounds great. I just have had enough of having a speaker amp at my computer desk, and want to simplify my desktop setup with my powered speakers.
I will keep you posted
Hey, thanks for the heads up. I haven't got anything yet, considering A70 pro (or maybe L70) now. That deal looks great, hope you get it and happy listening :)
Hey man, my SMSL H400 finally arrived the other day, and I’ve had some time to test it out. This unit is definitely complete overkill, which isn't a bad thing.
Even with a -6dB preamp reduction and a heavy +6dB bass shelf in my EQ software, I am only hitting 40% to 55% volume on high gain to drive the HE6se v2.
With eq applied, the h400 seems to have a better control over these drivers compared to the L50 from what I can remember.
L50 started sounding a little "loose" with hard hitting bass with eq applied when I was comparing to the speaker amp set up I had.
Unless you plan on pushing an even more extreme EQ profile than that (or at all), the Topping L70 will have more than enough power imo. It really stands out as the best value option here.
At the end of the day, I think you will be splitting hairs trying to find any audible difference between the L70 and the A70 Pro. Unless you find a good deal on a the higher end model, the L70 is likely just fine.
I have never used an L70 keep in mind. I have owned one amp with half the power (Topping L50), and one with double (H400) so my guess of the L70 being satisfactory is just an estimate based on gear I have used.
Cheapest route now unless you already have a speaker amp appropriate for it is the Fiio Gigas1, and you will have the option of trying 5V and 12V to see if you can hear the current reserve effects. Don't forget a balanced 4.4mm cable. BTW, leave the amp gain switch to low unless you are running out of clockwise rotation on the amp pot. The PSU PD negotiation dictates the current available, not that gain switch on the amp.
