staticV3
- Joined
- Aug 29, 2019
- Messages
- 14,256
- Likes
- 24,545
DFU mode is only for flashing the firmware.Yesterday I received the A70 Pro. Very nice and compact, though the finish is average at best. My first impressions are that it drives the Abyss 1266 fantastically well. BUT every time I turn it off from the amplifier and then turn it back on, it freezes, and the screen shows “DFU version v2.05.” If I switch it off from the back and then turn it on again, everything works correctly. Is this normal? I think it’s going back to Amazon.
Regards,
According to Topping, the A70Pro should only go into DFU mode by flipping the power switch at the rear off, then back on while you press down the volume knob.
The Amp shouldn't go into DFU mode if you're not touching the volume knob during boot.
You could try updating the firmware, see if that helps: https://www.toppingaudio.com/download/a70-pro-version-v2-05-firmware-update
