Thank you very much for the suggestion.I don't think you'll have any luck with either headphone amplifier.
According the Specs the Aune S17 Pro Evo delivers 7,5W at 32 Ohm.
According to @amirm's measurements, the A70 delivers 8.22 W into 32 ohms.
Therefore, I expect the same inadequate results from the significantly more expensive Aune S17 pro.
The S9C Pro only has a power output of less than 5.5 W at 32 ohms. Therefore, it will reach its limits even faster.
I therefore recommend buying a power amplifier for your insensitive headphones, as most headphone amplifiers deliver less power at 32 ohms than the A70.
An excellent choice may bet the Topping B100 amplifier. He delivers 100W at 4Ohm which means 12.5W at 32Ohm. This will probably be sufficient. You need an adapter from Banana to XLR or 4,4mm TRS and you're done. Cheap solution and power without end...
If this still isn't enough get a NCx500. It will deliver 500W at 4Ohm which means 62,5W at 32Ohm.
Best DrCWO
To keep costs down rather than buying 2x B100 (they do look fantastic and extremely low distortion), I'll be running a Topping E70 DAC with this setup, how would a Topping PA7 or PA5 II fair instead?
Which specs in particular of these amps am I most interested in to ensure these power amps are ‘suitable’ for headphones.
The planars I’m struggling with are 11-ohm.
