Yersinia Bestmate
- Joined
- Nov 2, 2023
- Messages
- 250
- Likes
- 148
No issues here either. Works as promised, beautiful crystal clear sound, tons of power.
Yes, absolutely. You can choose the output: XLR, RCA, or XLR+RCA.Is it possible to use the RCA and XLR output at the same time?
I am thinking here of the application of a subwoofer, i.e. one output (XLR) to the power amplifier and the other output (RCA) to the subwoofer.
What exactly do you want to do with the A70 Pro on your computer?I am currently having an issue where my topping a70 pro is not being detected by my computer. The firmware is on version 2.05 and my pc drivers are completely updated. The application is being detected as "Unknown USB Device (Device Descriptor Request Failed)" driver error, but all my drivers are up to date. I also have updated the firmware on my a70 pro, even though it was already on ver. 2.05, just to see if it would do anything. Lastly, it enters DFU mode whenever I plug in my usb c cable. This happens whether or not I am holding down the volume button.
Does anyone have any ideas as to how to help me or how I could solve this?
???I just want to use it for better audio control when listening to music
You can connect it to the analog audio output of your computer or to an external DAC.I see, then I understood the A70 Pro wrong. But, with that said, how would I connect it to my computer or other devices? This is my first major amplifier as the previous ones were just able to connect and play. It may be a dumb question, but does the A70 Pro NEED the D70 Pro to function. When I had looked it up before, it had said it did not and could function without it.
Topping hat übrigens mit dem D50 III einen symmetrischen DAC mit EQ über USB im Programm, der vergleichsweise günstig ist und ebenso gut getestet wurde wie der D70 Pro.Ah, ich verstehe. Ich habe vor, mir in etwa einem Monat die D70 Pro zu kaufen, daher werde ich sie vorerst an die analogen Audioanschlüsse meines Computers anschließen. Vielen Dank für Ihre Hilfe, ich weiß das sehr zu schätzen.
Yes you can connect the A70Pro's XLR Line out to an external Amp.hi all
Is it ok to use a70 pro preamp xlr out to my hifi amp?
its a cambridge cxa 80.
cxa80 xlr in voltage is 4 volt
my setup is adi 2 dac fs to a70 pro xlr out to cxa.
is this safe?
the manual talks about connecting to speakers but not hifi amp.
amirms test shows xlr out 4v at -6 volume.
so -6 on volume of a70 pro will give me 4v out to cxa?
iam not brill at this help required
thanx
Where did you get the information that the A70 Pro damaged or destroyed headphones?I'm looking to replace my THX 789, and this thing really seems to fit the bill. Digital volume control (the pot on my 789 wore out badly), tons of power (I have a set of HE6se's in my collection), screen with a VU meter (I'm a sucker for things like that), etc. The only problem is all of these reports about it failing, or rather, headphone damage. Failure is annoying, but damaging other gear is unacceptable.
I'm thinking about getting one, hooking it up to a pair of headphones I don't mind losing, and letting it run for like two weeks straight, really hit it with a lot of service time to see if I can get a fault to show up before I swap it into my main gear stack. Is there any consensus on what could trigger this? Any specific songs, any combo of inputs and outputs? I'm not going to use this as a preamp at all, so ignore that bit. My primary usecase is balanced in/balanced out to headphones.
Did they ever nail down a specific cause and address it? I've seen some posts that it could be the potting compound used, which to me means firmware updates are unlikely to make a difference. Has that been corrected or do you still roll the dice on buying one of these?
Earlier in this thread, in fact. Page 32 I think? There's a posted video that shows the popping and a follow up post from the same user mentioned that the driver wasn't the same afterward. There's a few other anecdotal reports that I had but I've sadly lost them amongst the hundreds of tabs I had open while researching into this.Where did you get the information that the A70 Pro damaged or destroyed headphones?
The volume control is relay-based via resistors, not digital. The signal in the A70 Pro is processed purely analogue.
Unfortunately, I have no new information about the modules. Perhaps Topping has solved the problems or left out the potting compound, as in the DX9, for example.
