Yersinia Bestmate
- Joined
- Nov 2, 2023
- Messages
- 256
- Likes
- 154
I suspect it is because:
- The A70 Pro's output gain is +6dB on the XLR vs RCA, so the volume towards your speakers is twice as strong as the signal the subwoofer. That may or may not be the same as from the NAD, but I suspect your NAD took care of ensuring volume amplification levels were matched between what it sent to the floor speakers vs the subwoofer.
- The A70 Pro is now sending the full audio frequency towards the floor speakers, including low frequency below the cutoff that would have been applied by the NAD. So anything in the range that your floor standing speakers can produce is now being added (at perhaps 2x the volume) to whatever your subwoofer is producing (at only 1x the volume). For example, the bass in the 50Hz. And the stuff in the subwoofer below 35Hz (which is below what your floor speakers do) is potentially only coming through at half the volume (i.e., 0dB gain vs. +6dB gain) relative to the volume coming from your floor speakers.
Thanks for your reply!
There was no high-pass filter in my ancient Nad for the main speakers so that cannot be the case, ie. the full frequency range went to the main speakers. Moreover, I cranked up the sub's gain a fair bit trying to match the volume difference between xlr and rca outputs.
I just measured the response and there was a 20db mountain at 55Hz and -15db deep canyon between 20Hz and 45Hz, centered at 35Hz. Perhaps there's something wrong with my sub. It used to get mono signal from the Nad, now it recieves stereo signal from the A70pro (the sub has stereo in, of course). It's an old sub, from around 2005 I think. It's been recapped and worked like a charm until this upgrade. I'll try to get a stereo to mono cable tomorrow and see if it helps. Weird stuff indeed.. and frustrating.
edit: elaborated the -15db canyon anomaly.
