Roland68
Good that you mentioned that.Yeah, I can be a sucker for that sometimes. In the end, I think the money would be better spent on a nice pair of headphones instead, but that's a whole other thing I know nothing about (and won't get into it here). Also, if I didn't have external speakers, I probably wouldn't have given it a second thought, and purchased the A50 III anyway. I have a few other questions about the L50, but I will do that in the appropriate thread.
Thank you both (yourself and @staticV3 ) for being so kind with your advice/insight.
Edit: One of the things that I think caused me to start this discussion was that the headphone output isn't balanced, despite having the XLR connector on the front.
You get exactly 0% advantage from a headphone amplifier with a balanced output for the headphones compared to SE with the same power. Absolutely 0!
You can even get disadvantages because the background noise of the two power amplifiers per channel is added together, but most manufacturers compensate for this through development and very low noise levels anyway. This topic has been discussed several times here in the forum.
I own a few HPAs, SE and Balanced myself, and I have never been able to detect any sound advantage of Balanced, only in relation to the Balanced and SE HP output.
The 4-pin XLR connection in the L50 is actually an advantage because this plug connection is much higher quality. You can also solder this plug onto any headphone cable later.
You're already in the right forum for good headphone recommendations, you should be able to find something in every price range.
