I don't think that many people are waiting for it and why should a test be necessary?Just wanted to remind Topping that a massive number of people are probably waiting for the measurements of this amp. It would be amazing, you know, if possible, Topping guys could send a unit to Amir ASAPThank you. Best.
...Im sorry that you are lonely, deprived of love and friendship
Just to push you over the edge, would also love to see measurements for the JDS Atom DAC 2, so there…
Easiest way is to buy one and ship it to Amir.I still wanna see the JDS review tho…
Connect one Amp via TRS and the other via RCA.what is the easiest, cleanest way to achieve the same setup that I have with the A50 III?
Then switch the D50III output according to which one you want to use.
You can plug both into the TRS output using TRS splitter cables.That's what I figured, but I also wanted to maintain a TRS connection all the way through to both amplifiers![]()
Though you'd likely have to make your own splitters as I'd assume the vast majority of 1/4" TRS splitters on the market are wired for Stereo single-ended audio which wouldn't work for this purpose.
Actually, I just looked and these seem to be more common than I thought:Yeah, that's the other problem - there aren't any splitter cables that are 2 split into 4 connectors.
Hosa Tech YPP-118 Splitkabel 0,2 m bei uns günstig einkaufen | Deut...
Stecker A: Klinke stereo, Stecker B: Klinke female stereo, Mantel: PVC.www.musicstore.de
Livewire Essential Headphone Splitter 1/4" TRS Male to Dual 1/4" TRS Female | Guitar Center
Shop for the Livewire Essential Headphone Splitter 1/4" TRS Male to Dual 1/4" TRS Female in and receive free shipping and guaranteed lowest price.www.guitarcenter.com
Stereo to 2x Stereo should work just fine, though I'd double check with a multimeter that there are no shorts.
Yes.Would that be the correct understanding?
Correct. TRS to one Amp and RCA to the other would be the rational choice.It all seems unnecessarily complicated![]()
The A30 Pro would not be an upgrade to the L50, almost the same measurements and minimally more power.I wish more of their headphone amps had a passthrough. I think the A30 Pro does have a passthrough as well, but because I'm not so up on headphone amp specs, I don't even know whether the A30 Pro would be a step up, down or a lateral move from the L50 (though, the A30 Pro review here seems to indicate it's a really good headphone amp).
Alternatively, I would bring the L70 from Topping into play. Absolute channel equality thanks to the relay-based volume control, double the power, built-in power supply and remote control.
Alternatively, you could build or buy an XLR switch.
The appeal of the new is understandable, but in this case it is probably not an upgrade. The L50 seems to fit perfectly in your setup.Definitely a lot to think about! Though, I think the more this specific conversation progresses, the more I'm convinced that the L50 I currently have is not going anywhere.
Since the A50 III uses the same circuitry and amplifier ICs as the A50S, there shouldn't be any big surprises. The A50S and the L50 were both measured at eye level and are already in the top places in terms of measurement technology.
I had both on my desk and the L50 stayed. It also has the advantage that it delivers high performance with any headphones and you don't need an additional balanced cable.
