perceptionist
- Joined
- May 1, 2024
- Messages
- 86
- Likes
- 85
With all the rave of TPA3255 PFFB, Topping just reminds people they are still there with a competitive MSRP. Looking forward to PA7 Plus reborn as Mini500.
Topping's reputation is that it always mostly lives up to its specs in independent tests.Lots of amp manufacturers promise lofty specs... my personal rule for audio products is don't spend a dime until it's been independently tested.
The problem was solely with the potting compound-filled modules, which are no longer used in the PA5 II and other devices.I think folks may also be skeptical because with the original PA5 amp (which has a similar design) had widespread reliability issues which damaged the brand IMO.
If they retain the input impedance of PA5II, it is 2k for unbalanced (not good for plenty of legacy hifi) or 10k for unbalanced (Archimago's measurements).Input impedance mentioned somewhere?
I did a search and didn't return results.
For me, it was less the problem itself (all companies can have problems like that) it was their failure to properly support the customers who had broken amps that damaged the brand.The problem was solely with the potting compound-filled modules, which are no longer used in the PA5 II and other devices.
These devices were replaced by Topping, or they could be repaired using the module from @gamerpaddy.
So, a problem that has long been solved.
Makes perfect sense, and it looks more modern with better WAF
I'd buy one if I already didn't have TP RA3
There's really one thing missing from the new one, and that's a remote. It's powerful enough for most speakers and will be underutilized on the desktop
Obviously it's possible to also control the volume through the DAC instead..
Heck, you could buy this without the significant other even noticing. It’s basically stealth technology.Makes perfect sense, and it looks more modern with better WAF
I sent an email to Topping and got this answer today:Input impedance mentioned somewhere?
Another SINAD chaser then as it seems.Unbalanced (RCA): 1 kohm
That must be a mistake - surely intended to be 10K?Unbalanced (RCA): 1 kohm
Early this year I asked the same question for the PA5 II.That must be a mistake - surely intended to be 10K?
Dammm... definitely a downgrade from PA5II (not that it was great).I sent an email to Topping and got this answer today:
Balanced (XLR): 5 kohm
That's odd: Archimago measured 10k (balanced) and 2k (unbalanced) for the PA5II.Early this year I asked the same question for the PA5 II.
The answer was the same as for the Mini 300, balanced 5 kohm and unbalanced 1 kohm.
shenzhenaudio.com
hifigo.com
