PA5 and PA5 II are also class D.If the spec sheet is accurate and this really is Class D, then despite similarities it should be a completely different amplifier under the hood.
Wouldn’t be surprised if this were a TI TPA3251.
Select the text you want to quote in the post you want to quote from. A little "reply" button pops up. When you click it you get the quote like I have here.(How do you multi-quote in this forum?)
and also Paco
We're talking about Topping, mate.Looks similar to what they already had... What is the point?
Absolutely.It's a great amp in version II, I don't mind at all a lower price and better looks. Can't believe people would complain.
At this point I'd just expect just about anything to cost more. My loudspeakers for instance cost about 1000 euro more than they did a year ago
Near field doesn't require anything close to 2x125wFor a near field desktop setup or something, this might be great entry point.
Agreed, could get into main system as well.Near field doesn't require anything close to 2x125w
As I said before, this is powerful enough for main systems, and should come with a remote like TP RA3
Welcome to ASR.I am new here and do have a question: why are small amps like the Mini 300 etc. despite their nominal performance mostly considered onyl for desktop/near field use?
I understand that the actual available power of the amplifier might not be enough to run big/low impedance speakers reliable and durable - Check.
But what about a standard living room setup, e.g. 25 sqm with normal bookshelf speakers like an Elac BS 244 at normal volumes?
I ask, because in the threads regarding the PA5 etc. many users seem to consider these small amps only as viable as secondary or desktop amp, and looking at the specs, measurements and the reviews I cannot really follow this assessment - what am I missing?
Are you sure it's a replacement for the PA5 II?Looks like PA5/PA5-II has got re-birth as new MINI300
I don’t know if they are going to now stop new PA5 II production but it looks to me the next iteration of PA5 II.Are you sure it's a replacement for the PA5 II?
The PA5 II's measurements are marginally better, especially at higher power levels.
If the image is accurate, they've definitely used significantly cheaper and smaller coils.
I would assume it's a cost-reduced/cost-optimized version of the PA5 II, where they tried to avoid significantly worsening the measurements.
The basic internal design looks very similar, as far as the picture shows.
In desktop setups, they are often used due to their relatively low price, good performance (especially low noise), and small size. Especially in near-field listening, a background noise or hum from the speakers can be very annoying. That's one reason why I no longer have active speakers. Since getting the PA5 II and Elac's DBR62/Carina 243, the background is completely silent.I am new here and do have a question: why are small amps like the Mini 300 etc. despite their nominal performance mostly considered onyl for desktop/near field use?
do people look for this from a power amp? I would think those the jobs of a pre-amp.The only, and for many a major, drawback is the lack of remote control for volume and source selection, apart from just two inputs.
Where are you seeing comparative measurements taken with the same test setup? Toppings specs seem almost identical - the only difference being 0.0003 vs 0.0004% THD+N.The PA5 II's measurements are marginally better, especially at higher power levels.
I'm not convinced it is possible to determine the performance/quality/cost of the coils from looking at a photograph. Yes they are smaller - that is all we know. This might simply be an optimisation - if for example the PA5 coils are over dimensioned.If the image is accurate, they've definitely used significantly cheaper and smaller coils.
Where are you seeing measurements?The PA5 II's measurements are marginally better, especially at higher power levels.
They're wrong. I've for instance used a Topping LA90 with less power successfully in a bigger room.I ask, because in the threads regarding the PA5 etc. many users seem to consider these small amps only as viable as secondary or desktop amp
