In my experiments If there's no mistracking or geometry issues with the groove (like a .3 on an inner groove), once FR is normalized I've not been able to to reliably hear the differences in a DBT, and I'm not aware of anyone else that has either.
That's quite a different statement than your previous post.
Torture tracks can be interesting from an engineering prowess perspective, but for the majority of people are rather pointless as a reference to performance with typical program material. Outside of IGD due to well-known geometric issues I've never come across a cart that mistracked on outer grooves that wasn't broken in some way or horribly mismatched with the arm. I've no doubt that others may have due to pathological setup issues or truly awfully designed carts, but such things shouldn't be used as evidence.
I'm not aware of any evidence of audibility of, say, a .3 x .7 elliptical on an outer groove vs. an LC/MR, or a boron vs. aluminum cantilever once level and FR are normalized. I'd imagine there's something out there with truly horrible distortion or separation that would be audible, but I'd consider that to be unusual, and not necessarily directly attributable to things like stylus shape or cantilever material.
Unfortunately most of my tests were long ago and I no longer have the files, but there are a few scattered about. IIRC I sent you the 2M Blue vs. Kleos (8/18 Al vs. 3/75 B) with no EQ, but there's also a 740ML vs. OC9XEN EQd. It'd be great if other folks interested in the topic put together and posted their tests, or at least the audio.
We're just not that sensitive to distortion, and the bar for separation is also rather low, not that cantilever material or stylus shape is going to have any meaningful impact on the latter. With stylus assembly swaps I've seen similar differences with similar magnitudes when stylus shapes and cantilever materials don't change, so I find it troublesome to attribute such changes to those things in a categorical way.
If you've data/evidence on the matter, please share it.
Also, it really pigs off advertisersYes, it is sad these kinds of tests are rare. They are costly, and we have to thank the largess of Canada's National Research Centre and the admittedly self-interest of Harman for advancing such tests.
Sure it's data, but what's the reference, other than a general preference for the nicest tone?DSJR,
Useless to you perhaps, but for the rest of us hard data, based on carefully controlled double-blind listening tests. My guess is that any of the components could change, and the results would be similar- repeatability: proof of scientific analysis.
That 'Toole Test' was useless really, as the conclusions basically showed how subjective the results were... Why not reference to the master tape or file that produced the vinyl? The SME III was a 'soft-gentle-warm-bland sounding arm with many cartridges (too much plastic in the pivot end), although later 'wands' seemed to perform better, but I'd never have fitted an MC type in it, unless it was a higher compliance Denon 304 or similar.
You forget what I was and how far back I goYou call an objective test useless because it wasn’t designed to provide data on what you want, and then go on a purely subjective and non-sensical critique of the tonearm used? “Because plastic”. Come on.
