I have a couple of speaker boxes that I have left over. They are not worth anything, I bought them for $10. I am thinking of mounting two Peerless SLS 10 (SLS-P830668) bass drivers in them, with an isobaric configuration. SLS 10 thrives well in at least around 45-50 liter sealed boxes. Isobaric, theoretically, allows for half the cavity volume. These speaker boxes are about 35 liters.
BUT what about the heat generated with a cone to magnet isobaric configuration? :
I mean it is a small chamber that one of the bass drivers pumps air/heat into. That heat is not going to disappear BUT on the other hand I don't know if it has any practical significance? Do you think it could get too hot and affect the sound of performance/quality?
My second question. With a cone to magnet configuration do you think there will be problems with a crossover point around 500 Hz? One SLS 10 played up to 500 Hz is perfectly fine but two in cone to magnet isobaric?
I was thinking SLS 10 together with Peerless tc9 broadband driver:
This is how the SLS10 is vented:
If I remember correctly, you @Duke have commenting about this with heat generation and isobaric, but I don't remember what you said?
