The frequency and phase look nice, but 132dB? This is approaching the "jet engine / gunfire" parts of the typical SPL charts...
Someone should ask DSL how they came up with that 132dB number.
As much as I find the prosound world to offer good science and understanding of loudspeaker principles, one area it has failed miserably at is in specifying max SPL.
I guess because in PA, where SPL means so much, it becomes an all too important spec, where marketing is willing to stretch things, or has to to look competitive to the undereducated marketplace.
Anyway, the typical prosound 'formula' for estimating max SPL, is to take rated sensitivity and increase that by the wattage rating.
For instance, say a driver has a sensitivity of 90dB and is rated for 250W. 250W = about +24dB.
So, some manufacturers will say it has a max SPL of 114dB.
But some will say, hey that rating is AES continuous, program rating is 3dB higher. So we can say 117dB.
And some will say further, but that 117dB is an average max SPL, we can add more for instantaneous peaks, maye another +3 to + 6dB.
So now we might see a max SPL spec of 123dB.
Which completely ignores any thermal compression, or the ability to produce the sensitivity rating across the entire spectrum, raised by power ratings.
Iow, optimistic bullshit at best.
The example above was of course for just a driver, not a full active speaker. But the principle is the same.
You can look at the driver sections employed in the speaker, and get a good sense of what realistic max SPL is available across the spectrum.
Get's pretty easy after you've built a few higher powered multi-ways.
In my estimation, there's no way the HRE1 can make 132dB across the spectrum, even if the SPL is defined as max instantaneous peak.
Maybe the 132 dB is a peak spec taken at a narrow freq range from the most sensitive and displacement capable driver section...
but ain't no way imo, that it's average SPL across the spectrum.
