Tom Christiansen Audio HPA-1 Headphone Amp Review
Angstrom
Cool. My suggestion of using a 30-second sweep and slower pot rotation still stands.
Tom
Looks like we need Adriano stepper motor controller attached to a servo in a jig to let you do this in an automated way.
Tom are you using a Linear pot?
I a/b HPA-1 vs Monoprice THX 887 today Single-Ended, it no contest HPA-1 is much nice AMP working a broad range of headphones Dan Clark ( Mr. Speakers) Aeon Flow Open, Hifiman Ananda (25 Ohms), Rosson Audio RAD-0 (29 Ohms), Audeze LCD-4 ( 200 Ohms). I had zero problems driving any of these headphones with HPA-1 without adding gain. THX no gain is level 1, I found I need Level 2 gain with THX with LCD-4 to volume match at a moderate level of volume.
With Rosson Audio RAD-0 I had 1/4 Single-Ended to HPA-1, and XLR out to Headphone from Monoprice THX 887 4 pin xlr jack, I still preferred the output of the HPA-1 Single-Ended. You have plenty of volumes, a very clean signal, and great dynamics.
Loving the AMP more and more
tomchr
Calgary, Canada
Feel free to build one and ship it to me. :) The thought did occur to me. I'd probably implement some sort of slip clutch so the stepper motor doesn't rip the pot apart. Then again, there are many other things I'd rather spend time developing. A filter so I can better measure THD would be good. As would a headphone dummy load with interface to the APx525.
No. Logarithmic.
I'm glad you like it. Thanks for sharing.
Tom
Music1969
It is fine, I have the Mr Speaker/Dan Clark Aeon Flow Open head phone, This is great mp for them.
What volume knob range are you using with HPA-1 and your Aeon's?
Is it already too late at 9 o'clock knob position?
Angstrom
No. Logarithmic.
Gs> Thanks.
Tom
Simpler solution might be tape a string to the knob and wrap a few loops around the knob then out to a winder it releases the last revolution
I am starting to develop a dummy load box. Moser dropped box load of parts. Maybe I look at microcontroller now to change values
trl
King of Mods
Iasi, RO
Finally... The measurements for the HPA-1 are now up. You'll find them in the Performance Graphs on the HPA-1 product page: https://www.tomchr.com/products/hpa-1
I'll go through and proofread tomorrow. I'm sure I can tweak a few sentences for clarity. The measurements can speak for themselves, though. I may add a few measurements as time goes on, but what's there is pretty comprehensive.
Tom
What I like most is the transient response and stability with regular cans. This is something that usually most manufacturers don't show to their customers:
"The oscilloscope screen shot below shows the transient response of the HPA-1 when presented with a 10 kHz square wave and loaded by 300 Ω in parallel with 470 pF of capacitance. This load is representative of a pair of Sennheiser HD-650 with the stock cable and a 2-3 m (~10') extension cord.
Of course, testing it with 10nF capacitance (equivalent to 100 meters headphones cable) really proves that this headamp is stable:
"Finally, when loaded with 10 nF, the amplifier finally shows slight overshoot and ringing. Note, however, that to obtain such capacitive load in actual use would require approximately 100 m (300') of extension cable on a typical pair of headphones. It is also noteworthy that the HPA-1 remains stable even with 100 nF capacity load. Needless to say, I have full confidence in the stability of the HPA-1.
tomchr
Calgary, Canada
Yeah. Those measurements used to be in every hifi magazine review. These days, you're lucky if you get much beyond sappy verbiage.
Tom
iamwhoiam
Just wanted to pop by and say great work @tomchr . I frequent DIYAudio and you pop up every now and then.
Then I saw the performance of this and was blown away.
Great job.
What's next on the horizon?
tomchr
Calgary, Canada
Thank you. I appreciate it.
Next up is probably that I write an actual business plan for TCA. Oh, you mean in terms of products? :) I'll try to get something ready for Christmas. I haven't decided what it should be (hence the need for a business plan), but I have some ideas.
Tom
Yviena
I'm just curious but when you decided on using the meanwell SMPS, did you manage to solve the ground leakage problem that these SMPS have, or did you decide to use their medical grade ones which supposedly has far lower ground leakage current? @tomchr
Julf
Amsterdam, The Netherlands
Ground leakage?
trl
King of Mods
Iasi, RO
Less than 0.25mA, per https://www.meanwell.com/Upload/PDF/IRM-15/IRM-15-SPEC.PDF, although not sure this makes a difference, given that LED appliances induce more current to the ground anyway. What's important is the installed RCCB to not trip.
tomchr
Calgary, Canada
I've been using the Mean Well IRM series since 2016 and have never measured any negative effects of any ground leakage. I've designed circuits that used various models of these power supplies and delivered noise floors below 1.0 µV RMS (20 Hz to 20 kHz integration bandwidth) so I appear to have solved whatever issue (real or perceived) that might be there.
I have had ground issues with the medical MPM series, however. That's a bit ironic given that they're supposed to have lower leakage.
Tom
Yviena
Tom
Interesting that the Medical grade series has issues i wonder what's different with them when they're supposed to be "better"
Also wouldn't negative effects of ground leakage if any only affect unbalanced signaling?
tomchr
Calgary, Canada
True. But the products that have used the Mean Well IRM series have all had some amount of single-ended circuitry, including the HPA-1. The issue I had with the MPM series (the medical version of the IRM) only affected the single-ended input. This is why we prototype... :)
Tom
tomchr
Calgary, Canada
tomchr
Calgary, Canada
I sat down with Thomas Turner of HiOnHifi last weekend for an interview. We ended up going into quite a bit of detail around Tom Christiansen Audio and what makes the TCA products stand out in the market. Enjoy.
Tom
jaibautista
I made an account here in ASR just to express how amazed I am with the HPA-1!
I had no plans to upgrade my amp (an RNHP that's been with me for almost two years) until a friend asked me to try the HPA-1 on his behalf when I dropped by a local shop, where portable/desktop audio enthusiasts usually congregate (pre-pandemic days) and buy music gear, last weekend. I immediately knew, during the first few mins of listening to the HPA-1, that this was a special piece of audio equipment; I left the shop with more questions than answers (and a sudden itch to return to headphones listening, from which I thought I had already moved on after getting a pair of nearfield monitors). I then spent the next week scouring the various audio forums, especially ASR, to research on not only the HPA-1 but also the company/man behind the product; the more I read about the HPA-1 and TCA, the more I became enamored about the idea of adding the HPA-1 to my audio gear collection.
Fast forward to today, and I finally gave in to the temptation! :D
@tomchr keep up the great work! Your no-nonsense engineering, design and marketing philosophy has made me a lifelong TCA fan. The praise you've been receiving for the HPA-1 and HPA-10, as well as the Neurochrome HP-1, is much deserved. Can't wait to see future TCA products!
P.S. @amirm ASR has been a godsend to me (and its members and readers); my recent audio purchase decisions have been heavily influenced by your excellent and candid reviews. When most audio review sites have effectively become shills and marketing mouthpieces, ASR has fully embraced its objectivist ethos that does a great service to the entire global audio enthusiast community. I can't thank you enough! :)
jaibautista
@jtwrace Thanks for the recommendation! I have yet to see any video/podcast featuring Tom but judging by his direct yet witty responses to queries/reactions directed to him not only in ASR but in other forums where he has a presence, I expect to learn (and laugh) a lot from these videos. Will definitely set aside time this weekend to watch the videos. Thanks again! :)
