There are stereo amplifiers with separate power supplies for each channel inside the same chassis. The only thing they share is the power inlet and mains cable. This is as good as monoblocks without paying 2 chassis.
Wow, even Fremer found the CJ's expensive in 1999!!!@beefkabob, there are exceptions to your statements, even in jest.
Because those Conrad Johnson monoblocks are just a special breed but for special circumstances. I'm jealous.![]()
Wow! Just because some tightwad on youtube badmouthed the Ferrari GTC4Lusso because the price tag was $343k USD; does it make the Lusso something to NOT lust after?Wow, even Fremer found the CJ's expensive in 1999!!!
As a major contributor and donor on ASR, you don't have to lust over any hifi!Wow! Just because some tightwad on youtube badmouthed the Ferrari GTC4Lusso because the price tag was $343k USD; does it make the Lusso something to NOT lust after?![]()
I've not seen measurements of the CJs, but I don't expect there's any reason to spend so much on amps that perform so poorly.@beefkabob, there are exceptions to your statements, even in jest.
I have done my bidding over the decades in all types of hardware and have the t-shirts!As a major contributor and donor on ASR, you don't have to lust over any hifi!![]()
Why not just software to eq out the frequencies that irritate you and add in some harmonics? The run quality solid state hardware. It's orders of magnitude cheaper, you'll have actual control, and everything will sound far better.As I get older I'm caught between the old and the new. I know for the type of speaker I use and what I like to hear Cary valve
gear checks 7 of 10 of the boxes for me. Their mono-blocks as nice as they look and as good as they can sound, I still prefer the older
model stereo V12Rs. I have tried everything Cary has. I keep going back to a pair of stereo V12Rs with EL34 Ruby's and Blackburn signal
valves. At 68 my ears are very prone to fatigue.
The new GaN1 or most of the newer pass equipment don't fry my ears with the transducers I use. I can love what I hear but the measure
of tolerance my ear/brain can take from some solid state amps is "how long can I listen"? The fact many SS amps wear me out in less
than 30 minutes is a fact for ME.
I actually know why I like certain valve gear and some may not. Ralph from Atmosphere explained it to a group of us several years ago
quit eloquently. The voicing (transformers bandwidth), valves, the amount of distortion, and second order harmonics = what many like
to hear. There was more to it but that was the largest part for me.
I use mono blocks, stereo, or 3 channel with their own PS. It doesn't matter who does what as long as I follow the basic rules above.
If I was going by how the amps specked out vs how they sound with my speakers and setup, SOME might not even listen.
I won't continue listening to anything else. My Ears, My Brain, My Rules. LOL BUT at least I know what I'm listening too, why I listen
to it is a different story, could be a brain injury for all I know.
Regards
Just by reading @OldHvyMec post; I readily figured why not software eq for him.Why not just software to eq out the frequencies that irritate you and add in some harmonics? The run quality solid state hardware. It's orders of magnitude cheaper, you'll have actual control, and everything will sound far better.
Truthfully, that blue background, and flickering VU needles always has an allure! Although, as I last saw them, in American Horror Story, not sure about the vibe, now!I have done my bidding over the decades in all types of hardware and have the t-shirts!![]()
Integrating amps in speakers then have other issues. Speakers tend to survive longer than amps, so when the amp dies the speaker, that is still in good working order but the amp, becomes useless. So i never do it, even when using plate amps, they get their own cabinets.Assuming the amp designer is competent, modern units do not suffer crosstalk problems when sharing a power supply and chassis. It is a good thing that multiple channels share a power supply, when one channel is lightly loaded, another can draw extra current.
Some people are correctly stating that monoblocks allow closer co-location of the speakers and amplification, reducing line noise and signal loss. However, the logical conclusion of this thinking is just integrating the amplification into the speaker itself.
Moderately interesting boxes, though.
"300 Watts rms from 30 Hz to 15 KHz at no more than 1.5 % THD into 4 ohms"
That's objectively not so impressive.
Purchased second hand Matt, can I ask what sort of costs you have needed to outlay on them since?Yeah, that's why most of what I own is second hand, including those CJ Premier 12s.
Indeed. If I were looking for strict neutrality I wouldn't buy the Premier 12s.
I'd been using a lower power CJ MV55 tube amp (and tried other tube amps of similar power) but felt I needed more power with the variety of speakers I was having through my listening room. I bought the Premier 12s based mostly on Fremer's review and found Fremer's descriptions to be eerily accurate to what I heard (and continue to hear) from the Premier 12s, vs the other solid state and tube amps I tried out. Absolutely bang on. It's one of the reasons I still can get something out of some subjective reviews - the "but what does it SOUND like?" aspect.
(And even if, in the end, the "sound" I hear amounts to some perceptual bias effect, I'm ok with that since it has been a very robust and reliable effect for the over 20 years I've used the amps. Utterly delighted with them).
I honestly don't understand why you would want musical gear that wasn't neutral. I understand and support room EQ. I understand theoretically EQing for a badly mastered song, though I'd not be interested in changing my EQ for every track or even every album. I understand pumping up the bass for older recordings that lack it, especially if played in a public event. What I generally don't understand is purposefully choosing equipment with lots of audible distortion. It just muddies up the music.Indeed. If I were looking for strict neutrality I wouldn't buy the Premier 12s.
I ask because I have long looked at Quad tube amplifiers.
Well, I can understand one situation for loving distortion in music playback. My friend has done a lot of production work, and a lot of the music he loves is poorly produced, which means he hears all sorts of errors in the recordings, all of which he finds distracting. By upping the distortion with low quality gear, he can hide some of the irritating details of the production and just listen to the music. Fortunately for him, poor sound reproduction can be found for cheap.
