Title: Hypex NC500MP – Identical mechanical hum from two monoblocks, persisting after power-off
Bigbro
Hi everyone,
I own two Audiophonics MPA-M500NC monoblock amplifiers, both using the Hypex NC500MP module with its integrated switch-mode power supply.
I’m very pleased with their sonic performance, but I’ve noticed something unexpected: both amplifiers produce a very faint mechanical humming or buzzing sound from inside their enclosures.
I expected these amplifiers to be virtually silent.
The noise is barely audible at approximately 50 cm in a very quiet room, but clearly noticeable when listening closer to the enclosure. Both units produce virtually the same sound.
Tests performed:
  1. Disconnected all XLR signal cables and 12V trigger connections, leaving only the mains cable connected. No change.
  2. Connected one amplifier to a completely different mains circuit. No change.
  3. Lifted the amplifier off its supporting surface and held it on my forearm to eliminate resonance through the furniture or floor. No change.
  4. Compared both monoblocks. The noise level and behaviour are practically identical.
  5. Used an iPhone sound-level meter. Background noise was approximately 25 dB with the amplifier off and 26 dB when on. I realise these readings are not sufficiently accurate to quantify such a faint noise.
The most interesting observation occurs when switching off the mains power:
  • The mechanical hum immediately becomes quieter.
  • It then remains at approximately the same reduced level for around 10 seconds.
  • During the final few seconds, the noise fades away.
  • Total time before complete silence is approximately 14 seconds (estimated).
  • Switching the amplifier back on immediately restores the original humming level.
Both amplifiers exhibit essentially identical behaviour.
Audiophonics customer support has confirmed that these amplifiers should operate silently and suggested disconnecting the input sources, which I have now done.
My technical question:
As the NC500MP includes an integrated SMPS with standby circuitry, could the noise originate from mechanical vibration (coil whine or magnetostriction) in one of the power-supply magnetic components?
Could the delayed disappearance of the noise after switching off be explained by the standby supply continuing to operate temporarily on energy stored in the primary capacitors?
Or is there another, more likely explanation?
I’m particularly interested in hearing from NC500MP owners or engineers familiar with the Hypex integrated power-supply design.
Is a faint mechanical hum normal for this module, or should both units be completely silent?
I am considering purchasing two additional monoblocks using the same NC500MP module, so understanding whether this is inherent to the module or related to its implementation would be very helpful.
Thanks in advance for your insights.
De
Possibly mechanical as you suggest, and stored energy. I'd push on transformers (power removed) first and see if any are loose.
Second idea, lid off, pull power cords and see if you can identify where the noise comes from a bit more accurately.
It is a known problem affecting the lower power all-in-one Hypex boards (125W/250W). Seemingly not every unit, though:
