tips to equalize my measurements
zag55
Right Channel
Left Channel
Wayne A. Pflughaupt
Corpus Christi, TX
Don’t see much that needs to be done with that, it’s excellent. 30 Hz is a bit hot in the right speaker, but lacking in the left, so combined it probably averages out about right.
How does it sound? That’s the main thing rather than what the graph looks like.
Regards,
Wayne A. Pflughaupt
Z
zag55
dopo un po 'soffro di stanchezza all'ascolto
MarsianC#
Austria
Not bad. Adjust target/house curve and you should be fine.
Would you mind sharing more details? I guess your room is well treated.
MarsianC#
Austria
RT60 means 60 dB down, impossible to measure with normal noise level and low measrument level. So measure at least 10 dB louder. You can also upload your .mdat.
And please, use deepL ;)
Waterfall should be scaled according to max. SPL with 60 dB range, 300 ms timewise.
