@fieldcar
Saw your old post about replacing the CD on your 590 and have a question on the process of removing the waveguide.
From the blow up view in the tech manual, it looks like 4 pins locate it and 2 screws secure it.
I figured there was some mastic or adhesive around the perimeter based on what I saw on a video on disassembling the 305 and 308 powered monitors. There was some black sealant of some kind holding the entire baffle on. If I recall, they used heat to soften it and gently pried around the perimeter to take it off.
My concern with the 590 is that heat to soften the mastic may also loosen the vynil wrap in the process.
Any guidance you can give me on the process would be greatly appreciated.
In my case, I am thinking about a CD upgrade since JBL crosses over 400Hz below the recommended minimum for the 2414. One of the 3 notch filters in the crossover is to try to reduce the resonance near the crossover.
I built a Center to go with my 590’s ( since the 520 is a bad joke) using a B&C CD and Faital Pro midbass drivers. Frankly, it is much cleaner and resolving than the 590, and has significantly more output capability, so a CD change to something more capable should help, if done right.
Thanks for any tips you can pass on.
Joe
Joe
