For a little ESP32-based audio project I am trying to work out if this module fits my needs and how.
www.tinysineaudio.com
Basically I am wondering if it can be made to
One thing that's unclear to me is how the unit is to be configured to output either of the supported
Anyone who could shed some light on this? Thanks so much!
Edit: numbered questions
TOSLINKBee SPDIF to I2S Digital Audio Receiver Module
This TOSLINKBee module can convert SPDIF optical audio singal to I2S output. It has a TOSLINK receiver on the module and two 10 pin 2.0mm male pins. DIR9001PW converts the SPDIF signal to I2S, and CS8421 converts the audio sample rate. TOSLINKBee can automatically adapt to different sampling...
This TOSLINKBee module can convert SPDIF optical audio singal to I2S output. It has a TOSLINK receiver on the module and two 10 pin 2.0mm male pins. DIR9001PW converts the SPDIF signal to I2S, and CS8421 converts the audio sample rate. TOSLINKBee can automatically adapt to different sampling rates devices, from 16bit 44.1KHz to 24bit 96KHz. TOSLINKBee is a I2S slave device, It can work with all our DSP digital amplifiers. If you replace the AudioB Bluetooth module with this TOSLINKBee, the whole amplifier will become a new TOSLINK input amplifier board.
Pins define
5V is input. 3.3v is output
Features:
- Size: 40*35*20mm
- Biphase Input Signal Sampling Frequency (fs) Range: 28 kHz to 108 kHz.
- I2S: Sampling Rate: 44.1KHz to 96KHz
- I2S: Bit per Sample: 16 bit or 24bit
- Input voltage: 5VDC
- output a fixed 24/96 signal,
- while at the input side supporting variable bit depths and sample rates.
- As it is an I2S slave device I take it the first bullet is determined by the I2S master, in my case the ESP32 board, specifically by the *CK signals it generates. Correct?
- How about the second bullet - is this also set by the I2S master through its *CK rates?
- If so, how is this in line with what's in section 4.2 - Mode selection (p. 17) of the attached CS8421 data sheet, where it says that output bit depth selection is set and fixed by means of resistors?
- Has this in this component been set to 24 bit so that 16 bits also fit, or does it not work that way?
