This is a review, listening tests, EQ and detailed measurements of the TINHIFI HUO IEM. It was sent to me by the company and costs US $23.
I immensely appreciated the red and blue dots indicating which is which (Red for Right). The quality is very good with the exception of the provided silicone tips. The medium one nicely fit my GRAS 45CA headphone measurement fixture. But the larger one did not for my ears. It simply made no seal as it lacks structure and stickiness. As you see in the picture above, I swapped them for tips from another IEM I had (the included ones are gray/translucent ones).
The HUO is comfortable to wear, not being too light or too heavy.
This is not a complaint specific to this IEM but I wish manufacturers would find a way to indicate what model these IEMs are. If it doesn't fit, let's at least have it on the velcro band or something. It took me quite a while to figure out which IEM this was.
TINHIFI HUO IEM Measurements
The frequency response instantly put a smile on my face due to its close compliance with our target:
We have a bit of deviation which we will examine with EQ in listening test section. For now, if you feel like EQing, this is how far it deviates:
I must say, I was not prepared for what came next:
The HUO seemingly doesn't know the meaning of distortion! Even at very high playback level of 114 dBSPL, the (green) graph barely lifts above bottom! At 94 dBSPL, you might as well call it distortion-less.
Impedance is low which means you can drive it with just about any portable product regardless of their output voltage:
When you combine it with better than average sensitivity:
I am listening with Topping DX5II as I type this and -40 dB is a comfortable everyday level.
Group delay is rarely revealing for IEMs and such is the case here:
The sudden change at 100 Hz is due to "rocking motion" of the IEM not staying still in the artificial pinna (you see a bump in the frequency response just the same).
TINHIFI HUO IEM Listening Tests and Equalization
First listen delivered that delightful, audiophile experience I expect in IEMs that comply with our target. Beautiful deep bass combined with incredibly clear highs. Could stop here but curiosity calls for EQ correction to our target (even though the target is approximate). Manual attempt did change the tonality but I couldn't say if it was or was not better than stock tuning.
So I asked ChatGPT Pro to create a correction but limited to the same four filters I had created. Three of its filters were very close to mine but the forth was not. In AB testing, I preferred the AI generated one to my manual one:
The difference with stock tuning is subtle and I can only describe it as having a bit more detail and maybe the reduction in upper bass. The only way I can rationalize this is with the boost in band 2.
Here is the robot report on what it did:
Accuracy Relative to Harman Target
Evaluated from 20 Hz to 10 kHz:
| Metric | Original | With PEQ |
| RMS deviation | 1.3 dB | 0.8 dB |
The correction reduces average deviation while avoiding excessive adjustments.
Observations:
- The bass response is already reasonably close to the target.
- The largest useful correction is in the upper bass/lower midrange.
- The filters improve midrange accuracy without introducing large boosts.
- Deviations above 10 kHz remain largely uncorrected because they are more sensitive to insertion depth and measurement conditions.
Unlike me, it is not too lazy to produce a before and after graph:
There are days that I hate what I do here, and days which I absolutely adore. Today was a combination of both. Started to test an wireless IEM which would not pair with its app, nor stay in my ear. Threw it aside in disgust, looking for something else to test. Saw the HUO in a sea of a lot of other IEMs I have here to be tested. The frequency response, distortion and then listening tests could not have brightened my day any better. Here is a company that is not even on my radar yet has delivered exemplary performance when no one was looking. And did for retail price, including shipping of just $23!!! Amazon says I can have it the next day no less!
The TINHIFI delivers a well engineered IEM that complies with the best research we have in IEM fidelity. No wonder it delivers on all fronts.
My only ask is that they include a larger/stiffer silicon tip so that it can fit my ears better.
If you have been sitting on the sidelines of IEM experience, this is your chance. For less than the cost of fast food for two, you can get an IEM that blows away most audio systems regardless of price! Get the HUO, make sure the tips fit your ear and be prepared to be impressed.
I am happy to recommend TINHIFI HUO IEM.
Any
donations are much appreciated using
: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
