totti1965
Thanks Amir, fabulous IEMs.
With products that good, isn't it time for distortion to be plotted on a log scale?
Nick
If @amirm plots Impedance of speakers, log scale would also be much better than linear scale!
This is because, if you raise the impedance by factor 2, the speaker will be quieter by exactly 6 (3?) dB, which is per definition a logarithmic scale. And it is NOT: if you add 1 Ohm of Impedance, the speaker will be quieter by this and that dB margin! So: linear scales for Speaker Impedance makes no sense.
Every other scale in the published charts is logarithmic. Be it the Distortions, Noise, Output Power, Frequency Plots or whatever else - and that’s for a good reason:
You would need a damn long piece of paper, if you want to plot the soundpressure per square inch which a 10 Watt Amp produces with speaker X in Comparison to the soundpressure of a 640 Watt Amp with the same speaker.
The paper had to be 64 cm long in comparison to 6 cm with logarithmic scale (10 x 2 to the power of 6).
Amp 640 Watt is percepted 8 times as loud as Amp 10 Watt (if I am not wrong, or was it just 4 times?) and NOT 64 times!
This would make the differences between two amps looking a lot less spektacular than in linear scale.
It would be also a much better visualisation of any problems a power amp could went in.
The logarithmic scale should be standard for every test.
So in 2023 I suggested that also for damping factor measurements of Power amps to Diego Estan from Soundstage network.
They included it immediately!
This is why I think that people from english speaking Countries (Soundstage network is Canadian) are a lot more open and less arrogant than germans.
If I write an E-mail to a german Loudspeaker brand, normaly they completely ignore it (Karl Heinz Fink from Epos-Loudspeakers / Fink Team is a rare exception!)!!!
By the way: I prefer the logarithmic scale also in long term stock market charts. It represents human perception more than absolute linear values.
E.g.:
Anthem MCA 225 Gen 2 Stereo Amplifier Measurements (Oktober 1, 2025)
