Cheap hybrid BA IEMs with extremely low distortion? I’m very surprised. Though it might be possible that the BA driver isn’t producing any sound, as is the case for some old KZ IEMs.1DD + 1BA for that price with that tuning? I am impressed. Looks good too!
I have a Zero 2 and also have a problem with it, from the beginning. The connector on one side has a connection issue, that screw up the sound, and even the IEM detaches from the connector time to time. I will order this HUO right now. I also have an old, original T3 from Tinhifi, which i really liked, it has great build quality.The performance of these are just as incredible as the 7Hz Zero 2 and Truthear Gate, which I own both.
Thing is with at least those two that the cost savings seem to be in durability. I've had a pair of Zero 2 in the past where one of the earbuds started dying and got lower and lower so I got a new pair, and the same thing happened to that pair just the other day. So I got out my Truthears and noticed that one of the channels in those also had started dying, just not as bad as my Zero 2.
So I'm curious how durable these Tinhifi is? We probably don't knwo yet, but I guess I'll have a go with them, especially because of the low sensitivity, they might be able to play at decent volumes from my old iPod Nano, something the Zero2 or Gate can't.
Too bad these are two shiny, and have these ugly red and blue dots on the outside of the buds (inside would make much more sense).
Interesting to hear you have somewhat the same experience. Thing is that I just tried my old pair (which I kept just in case) and they seem to work almost perfectly now, so not sure how that happened. But yeah there clearly is something with the build quality of the Zero 2.I have a Zero 2 and also have a problem with it, from the beginning. The connector on one side has a connection issue, that screw up the sound, and even the IEM detaches from the connector time to time. I will order this HUO right now. I also have an old T3 from Tinhifi, which i really liked, it has great build quality.
I've had the same issue and it got fixed by cleaning the filter, metallic one. A friend of mine bought one and one of the channels died on the second use, broken cable.The performance of these are just as incredible as the 7Hz Zero 2 and Truthear Gate, which I own both.
I am very curious how the fit will be for you.It is even cheaper than the 7hz zero:2. The price ratio is 1 : 1.4 in my place. I can not resist and just ordered 1
Its frequency response looks like in between 7hz zero:2 and truthear gate.
Yeah I did but there was no noticeable difference.I've had the same issue and it got fixed by cleaning the filter, metallic one. A friend of mine bought one and one of the channels died on the second use, broken cable.
Fitment and comfort is one which is a personal thing.why buy another IEM with now cheap and widely available Harman tuning?
