Time for new LR Towers
I don’t think I would - but that’s just me. This one is roughly equivalent to what I have, perhaps tracking a bit better, but definitely not a match for Blades.
The fact that this is their biggest center does not mean that they should have not made a bigger one - to match the Blades. That one, which they don’t have, would be the one for me.
Theoretically, it's the same UniQ mid/tweeter driver as found in the Blades, just with 6.5" woofers instead of 9". But yeah, if you want maximum bass out of the center, those might come up short.
The issue I see with a matching Blade center is how to set the side woofer array in a horizontal position.
Sure, you can use a single Blade as center, but that means you are bound to an acoustic screen.
Smoothest bass response I've ever been able to achieve across the room, when paired with two subwoofers. Wide sweet spot for listening. Before the Blades, I used to have three different Dirac calibrations that I switched between often. Now I have two, but in practice rarely swap between them.
There are some practical benefits as well. It's nice having no cabinet vibration even at reference levels. The feet and built-in spirit level make it very easy to get them perfectly level -- something I never quite achieved with my old R11s. They're pretty forgiving in terms of placement, I think the recommendation from KEF is 9" out from the rear wall.
Assuming you buy new, registering them will get you an additional year on your warranty (6-years total).
And of course they are gorgeous to look at. One thing to note is that the Frosted Blue finish on the Blades is *not* the same shade as the Royal Blue on the LS50 Metas! Just something to note if you have both. I do, but fortunately they are not sitting next to each other. :D
Were the R11's able to handle LFE+Main?
R11s are pretty bass shy. You can add a shelf to boost it up a bit, but still pretty underwhelming IMO. I don't miss them.
Interesting. I'm in the market for new front L/R speakers and recently was able to listen to KEF R11 Meta and Martin Logan Motion XT-F100 towers in the same room in two channel, driven by a McIntosh power amp. I was actually surprised at the bass extension of the R11's, given the limited cabinet volume.
Well I guess the reason might be that expectations are subjective, so what works for some might not for the others. It is a matter or choosing the pair that really meets one’s expectations, subject to considering objectively the measurements, availability of subs and various bass management options, or any room particular issues.
I was thinking more along the lines of being able to handle the current required to reproduce LFE and if the drivers are capable of doing so.
After Amir's testing, the lower end not being super strong was quite evident.
Have you looked at Paradigm Founder 120? It's a low-end monster for the money - no speaker in the price range touches their mid 20hz extension.
I have had the Paradigm Founders 120H on trial since Wednesday and I'm blown away by their looks and performance (clarity without harshness or fatigue at the top end) and deep and tight bass resolution. The cabinet work is just beautiful. I just told the dealer that I will buy them! See pictures
Awesome! Happy this helped and even happier you got the system you wanted with all requirements met. Also doesn't hurt that it looks great! :)
Glad u found what you were looking for. Out of curiosity, what is the F3 in your room?
It is the point where your bass response goes -3BB down from the reference 85dB. While we do have a lot of data that were taken in the anechoic chamber, usually the low end response in room extends below that. Not a point of reference as every room is different, but IMO still worth the question out of curiosity.
For perfect measurement one would also need the compression charts that show distortion vs SPL at various frequency levels, but unfortunately that is something that we don't get from reviewers, just occasionally from the enthusiastic members.
